WORKED ON UNTIL I INSTALLED NEW INK CARTRIDGES.
A lot of the ink jet printers have a copper color strap on the ink cartridge this contains the heads. If you are refilling the cartridges or have let the printer sit for a long time the heads can get built up dry ink stuck in them. Try taking the cartridge out and physically cleaning it using rubbing alcohol. If this does not work try replacing the cartridge.
SOURCE: Lexmark printer printing blank pages
hello sir,
dont worry this is d simplest case when either cartirage is choked or fileed with duplicate ink.
Try with another and if u still face this prob den reply
abhinav
Open up the "Printer Solution Center." If there is no icon on your desktop for your Lexmark printer, click on the "Start" menu button, which is located at the bottom left-hand corner of the screen. Click on "All Programs," and then look for "Lexmark." Select the "Printer Solution Center.
Choose "Install a new printer cartridge" under the "Maintenance" tab.
Click on "Next" until you see the "Print the Alignment page" option, then choose "Print."
Repeat steps 1,2 and 3 if the ink level gauge still isn't showing sufficient ink.
