1996 Dodge Grand Caravan Logo
A
Anonymous Posted on Oct 12, 2014
I am trying to locate the radiator fan relay on both a 1996 Dodge Grand Caravan. Can you help me with this?
I'm trying to locate the radiator fan relay on both a 1996 Dodge Grand Caravan, 3.3L. The fuse box cover under the hood of the 96 Dodge Caravan does not show the radiator fan relay, and under the dash does not have a cover with information as to which relay is for what? I need a diagram or label for each relay and fuse. The radiator works when hooked up directly to the battery. Can you help me with this?
Steve Harrison
Level 2:
Sergeant:
  • Dodge Expert 405 Answers
  • Posted on Oct 16, 2014
Steve Harrison
Dodge Expert
Level 2:
Sergeant:
Answers
405
Questions
Helped
147763
Points
814
On My 97 3.8 engine and my 99 3.3 engine it was behind driverside wheelwell. You take out the Air filter breather intake. once it is removed you will see it bolted to the frame, for a good ground. Clean up that area if there is any rust, you will not make a good ground. i think 2, 10 mm bolt and a big plug. it takes about 30 mins, to do job.
Mike Butler
Level 3:
  • Dodge Master 6,674 Answers
  • Posted on Oct 14, 2014
Mike Butler
Dodge Master
Level 3:
Answers
6674
Questions
10
Helped
2892071
Points
19845
Go to "Google images" and search for "Caravan relays" all kinds of pictures, just find one that matches yours.
ronald walker
Level 1:
New Friend:
  • Contributor 6 Answers
ronald walker
Contributor
Level 1:
New Friend:
Answers
6
Questions
Helped
1370
Points
11
5 Related Answers
ilragatzzo78
francisco navarro
  • 241 Answers
  • Posted on May 15, 2008
SOURCE: 1997 Dodge Caravan Fuse Box Diagram
i need your vin # to check the wiring diagram
there is at least five diferent ones
Anonymous
  • Posted on Feb 08, 2009
SOURCE: were is the fuse box in a dodge grand caravan 2003?
i have a 2002 caravan and the turnsiginals are only working inside the dash nothing outside has new bulbs and still nothing anyone any ideas?
Anonymous
  • 57 Answers
  • Posted on Jun 16, 2009
SOURCE: 2000 Dodge Grand Caravan need to know where relay
the cooling fan relay is not in the fuse box.
it is a solid state relay bolted to the radiator core support just behind the bumper
Anonymous
  • 49 Answers
  • Posted on Oct 28, 2009
SOURCE: fuse box diagram for 2000 Dodge Grand Caravan.
The panel or the housing normally lists the names of the items that are controlled by the fuses. If that doesnt work, disconnect the battery terminals and you are good to go
Anonymous
  • 645 Answers
  • Posted on Apr 10, 2010
SOURCE: location of radiator fan relay 1999 dodge grand
the relay is on the drivers side just below the headlight. you have to jack the car up to see it. it's bolted to the body with 2 8mm bolts. that is you have to use 8mm socket. It's black and about two inches square. It's a little hard to see but it is there. hope this helps leave comment.
4helpful
Where do I find the cooling fan relay switch on a 2000 dodge grand caravan sport.
RADIATOR FAN RELAY
The radiator fan relay is located below the left front headlamp module Radiator Fan Relay The headlamp module must be removed to access the relay.
REMOVAL
Open hood, disconnect and isolate the battery negative cable.
Remove the left side headlamp bulb from the headlamp housing.
Remove the left headlamp module.
Remove the cover over the relay.
Disconnect the relay connector Radiator Fan Relay
Carefully drill out the two retaining rivets.
Remove relay from vehicle.
1helpful
2answers
Where is the radiator fan relay located for 1999 dodge grand caravan?
the relay is located either behind the front left headlight , or on the frame rail under the front left headlight , dealer part only they have tons in stock
1helpful
31helpful
Where is the radiator fan relay on a 2006 grand caravan
The cooling fan control relay is located behing the grill in a crossmember (see the pic). It works in conjuction with the Integrated Control Module.
e0ef069.jpg1. Grill
2. Fan control relay
3. Rivet
4. A/C condenser
Hope this helps.
My vans ac fan doesn't shut off when i turn the van off i have to take the 40 amp fuse out under the hood to stop it what could be wrong 1996 dodge grand caravan
possiable fan relay melted which is located at the bottom of radiator on driver side (not bolted on radiator but next to it)
Radiator
ok ,generally on this car the fan relay is located in fuse box near the battery car
2002 Dodge grand caravan
It would appear that the relay is located on the cross rail that runs across the front of the vehicle (in front of the radiator). I found out that it is riveted in place by a single rivet, so in order to replace mine, I will have to remove the rivet and use a self-tapping screw to secure a new one.
The fan relay is located in the fuse panel located under the hood beside the battery. It will be marked under the lid. Make sure you check the maxi fuse for the fan also.
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
