From one day to another my Internet stopped working so after a lot of messing about with Broadband I got told to reinstall, now I have got no Sound and the Standby Button is shaded, my Daughter tried to solve the problem but cant do it, please could anone help. Thank you
Comments:
Jul 05, 2009
- Thank you for trying to help, but the problem is still there, I followed your Instructions but it says no Audio Device, the Volume area is shaded so I cant alter anything. Window Audio says startup automatic,so there is no problem with that, I dont know much about tecnical things,but would really appreciate help, Thanks a lot.
Check that sound is not on mute...click on the sound icon in your task bar and check through for checkmarks on mute....
Your audio service may not be started...
Go to Start>> Run>> type in services.msc.
A window will pop up with a list of services. Scroll down to Windows Audio>> Right-click>>Properties.
Make sure that 'Startup' is set to automatic. Click Apply and okay...Now check the startup status under services..Make sure it says started. If not look to the left and click start service...
Hope this helps...
Comments:
Jul 05, 2009
- A couple of other solutions that may help...
* Are the drivers installed...?
Go to manufacturers site and download the audio driver
* Check that your sound theme is set...
Go to Start/Control Panel/Sounds and make sure that your sound settings are set to Windows Default (or one of your choice).
I've been getting low pretty low FPS for quite some time in Left 4 dead. Right now I get about 40...
(More)
I've been getting low pretty low FPS for quite some time in Left 4 dead. Right now I get about 40 and it drops to 30 with a hoard. My FPS actually increased when i installed windows 7 64 from xp 32. I have a Dell XPS 700 Intel Dual Core 3.2GHz Windows 7 64bit 6GB Memory ATI 4890 In game settings I have multicore rendering enabled 1920x1200 AA 2x Filtering 2x Verticle Sync Double Buffered Shader Medium Effect Detail High Model Texture High Paged Memory High The only thing i run with the game is Vent
Hi. I'm using a Asus M2N-E motherboard and when I do a CMOS HDD's start to spin Fan of VGA Processor...
(More)
Hi. I'm using a Asus M2N-E motherboard and when I do a CMOS HDD's start to spin Fan of VGA Processor and main fan also start spinning but there is no picture on the screen and it seems the bios doesn't start up. About half a year ago I had the same problem but I couldn't solve it so I brought it to a technician but couldn't see what he did in order to be able to do it my self. I'm pretty sure there's nothing wrong nor with my VGA card nor with my Monitor since they were running just fine today. I was trying out some things and the PC freezed so I decided to shut it down and start up since I don't have a reset button but there was no response from the button and shut the power from it directly. Thought first that my CPU got fried but still restarded the CMOS and again nothing happened. After a few minutes I checked the cable connecting the button to the mother board and it was disconnected. I reconnected it and it started but it seems like I got a system boot failure and don't know how to fix it. Please do help me .
My packard bell i media 5075 is giving me a proplem that happens a lot when you turn it on it does...
(More)
My packard bell i media 5075 is giving me a proplem that happens a lot when you turn it on it does nothing but comes up with packard bell logo but if you tap the cpu fan and try again it will work it is realy enying cus a lot of the time it crashes please could some one tell me what is wrong with it.
