Washing Machines Logo
C
Chuck Posted on Oct 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is f5 error mean
Gives f5 then will not spin
Dennis
Level 2:
Sergeant:
  • Expert 232 Answers
  • Posted on Oct 12, 2014
Dennis
Expert
Level 2:
Sergeant:
Answers
232
Questions
Helped
59750
Points
546
F5 will be displayed if the selected water temperature is not
reached or the heating element has failed. Check the water
temperature sensor, heating element and element relay.
Check all connections. Whirlpool Customer Service can
be reached at 1 866 698 2538.
Regards,
Dennis
Kennmore Elite Washing Machine. It is made by LG. What is the F5 error on it please?
Question edited for clarity.
Question moved to model category.
Error code F 05 repair tips please. - Kenmore Elite HE3 ...
iFixit
https://www.ifixit.com > ... > Appliance > All Answers
Sep 5, 2015 - Error f5 is due to a fault in the wash temperature sensor sometimes due to a breakdown or a bad connection. On some occasions the resistance may ...
5 answers · 3 votes: Notsohandyguy, error F/05 means Water Temperature Sensor Error If during the water heating ...
F5 error code after washer has filled up with water? - iFixit
Oct 27, 2010
I have a f5 error code - Kenmore Elite HE3 Washing Machine
Aug 17, 2011
I am getting 2 codes E3 and F5 on my washer. - iFixit
Feb 18, 2018
Getting E3 and F5 on my Kenmore 700 series. - iFixit
Aug 15, 2018
More results from www.ifixit.com
How can I reset the error E.OP from my F5 Combivert inverter?
I may miss the point here. If the question is how to clear the error, page 57, item 4.7 Error Messages, of the KEB instruction manual may be of use. https://www.manualslib.com/manual/1293218/Keb-Combivert-F5.html?page=55#manual
Here is information about the error code:
KEB Error "E. OP"
ERROR overpotential (voltage)
1 Voltage in the DC-link cicuit is too high.
Occurs if the DC-link circuit voltage exceeds the permisible value.
Causes:
- poor controller adjustment (overshooting)
- input voltage too high
- interference voltages at the input
- deceleration ramp to short
- braking resistor defective or too small
Given the very technical nature of the KEB, I lean toward referring to the manufacturer's support. There are quite a number of KEB YouTube videos and a number of supporting documentations available on the web. Perhaps the following will be of use if not an entire misdirection: https://www.kebamerica.com/elevator-support/
https://www.kebamerica.com/products/f5-inverter/
2answers
Westinghouse dishwasher F5 error
google westinghouse dishwasher wsf6608x error codes f5
F5 signals an error in the water supply line, which may mean that the tap is not open far enough or that there is an error in water pressure
Westinghouse Dishwasher F5 Error - Water Level Fault
I have a brother innov-is 95e it gives me message f05 speed sensor how can i fix it plz help
Q: What does F5 error message mean? A: Dirty speed sensor Q: How to fix F5 error message? A: Unplug the sewing machine and check the timing shutter wiring connection on the main PCB assembly. If the wiring connection is okay, clean the timing shutter. Replace the timing shutter if it doesn't work after you clean it. If the problem persists, replace the main PCB assembly.
E.pu error in keb f5 inverter. the part no. is 09.f5.a1d-3a4a, ver. 1.0, 1.5kw. when powering up the drive, it gives 560VDC. please recommend what the problem could be.
The E.pu error is a general power stage failure.
Typically means that the unit has a defective power stage that would need to be replaced.
If it is an old inverter(early 2000's) there is a possibility that it could be a cooling fan problem since at that time there was a three wire fan used. May be able to replace the fan (must obtain from KEB) but there may still be problems with power stage. If it is from early 2000's then you might be better off replacing the unit with new current version.
Error code f5
There is no error code F5. Could you mean 05? That is a flash error
2helpful
2answers
Kenmore model 790.96113403 F5 error code
it means that your oven is showing a restart code
I have error code F5 on my Amana stove model #AGS761L. What does this mean?
here is what F5 means and the fix for it
F5 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
1helpful
F5 Error flashing
Hello sir; The F-5 means the exposure lamp bad, replace it, will take care your problem.
2helpful
F3 and F5 errors that shut off oven
F3 *Open Temperature Sensor Controller not receiving data from temperature sensor.
F5 *Control Output Disabled No control output.
Sorry you will have to replace oven sensor and oven control...
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
