SOURCE: motor runs but have no power coming out of outlets of mygenerator
1 - Check the circuit breakers on the front of the panel where the outlets are located.
2 - Make sure the black molex plug on the back of the panel where the outlets are located is plugged in securely.
3 - Carefully take the plastic endbell off the generator ( you'll need a 7/16 inch wrench and socket) and look for broken or missing brushes, broken wires, etc.
4 - If you're not up for #3 take it to a good repair shop. :-)
SOURCE: Coleman Powermate 5000 no electricity, runs fine
Hello;
Take a look at your outlets. Some of these units use pretty cheap outlets and short out. You will know if it is bad when you look at it. Hope this helps.
Thanks;
Rich
RPM Northwest
SOURCE: Need to know about this
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
SOURCE: Coleman powermate 3750 watt brand new I started it
Check the oil level & try again to start many times until it became loose because the engine became stock up for long time not use.
SOURCE: AVR board is burnt out
AVR burn out is the most popular problem with electricity supplyment....
replace the AVR...if it burnt out shortly after words..then u have a problem with the rpm of the engine...if not..then its just a AVR burnout..
don't hesitate to write to me for further information:
[email protected]
