Panasonic Shiatsu Massage Lounger with Electric Reclining Ep790k Logo
don amati Posted on Oct 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an electric recliner chair that is in full reclining position.Is their a manual release somewhere on the chair to put it back in its upright position?
Julie Clark
Level 2:
Sergeant:
  • Expert 266 Answers
  • Posted on Oct 12, 2014
Julie Clark
Expert
Level 2:
Sergeant:
Answers
266
Questions
0
Helped
79517
Points
606
Human Touch PC-075 Recliner is there a stop setting?
The Human Touch PC-075 recliner does not have a stop setting to limit the amount of recline. However, you may be able to adjust the recline tension by using the adjustment knob located under the seat. This will control the ease with which the chair reclines and returns to the upright position.
Adding a mechanical stop to the recline mechanism is not recommended, as it may interfere with the chair's operation and potentially damage the mechanism. It's best to adjust the tension as needed using the adjustment knob.
Feb 21, 2023 • Furniture
Lafer Recliner Back Won't hold or lock in positions
its not a car so moved you to chairs (random)
Aug 28, 2022 • Garden
My air med us8000 massage chair will not fit through the doorway. Can the unit be made to remain reclined after shut off or can the arms be removed?
Most large recliners have removable backs. You must lift the rear shirt and look for the release latches. There will probably be an electrical connector or two as well if the device is a massage chair. Once you remove the back, then you can turn the chair on its side and then it should fit through most doorways.
Jan 02, 2016 • Furniture
Flexsteel electric recliner positioned itself in full reclined position and is now stuck there. Help!
It seems that you have a short in the chair control. You should be able to get a replacement from the manufacturer. They can be contacted at http://www.flexsteel.com/home-furniture/customer-service/contact-us
Sep 09, 2014 • Furniture
My wheelchair's green light doesn't come on after I return from my reclining position
Contact Pride for a manual, you'll need one. Or a Wheelchair/ medical equipment outfit.
How do i recline the Peg perego Prima Papa high chair?
Lift up on the handle in the middle on the seat back. There are usually 4 stops along the way from upright to recline.
3helpful
3answers
Front seats recliners won't "click" in the upright position.
personally i would pull the seats and weld them into a position that is comfortable both sides of the seat should be welded. a small mig welder would take care of this issue nicely and permanently ! .. jay Florida
2helpful
3answers
Need to recline seat
On the back of the the seat back is a plastic tab connecting two lanyards/cords. These cords are used to adjust the seatback angle from the recline to full up-right position.
Top Panasonic Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Panasonic Furniture Expert? Answer questions, earn points and help others
