The picture has red line/lines in the middle. At the bottom when there is writing it is doubled. At first just the writing was off, now the red seems to be getting worse/bigger. How do I fix it. Please share any links to a repair kit and one that has detail instructions to follow. Thanks for any help.
Comments:
Jul 06, 2009
- How do you re adjust it??? I have model # PT-51HX41.
Jul 13, 2009
- I adjusted the convergence on the TV and the red will NOT adjust. What needs replacing and how do I do it?
Jul 16, 2009
- I called repair shops and one said we needed amplifiers replaced. How and Where do I get these.
Hello, I've got a Hitachi Rear Projection model 57F59A, and is dead. Replaced pico fuse and...
(More)
Hello, I've got a Hitachi Rear Projection model 57F59A, and is dead. Replaced pico fuse and transistor Q777. Worked for maybe 5 minutes then started arcing. Arced maybe 5 times and now I'm suspecting that 777 is dead again, I know related pico fuse is. I was trying to see where the arcing was and only saw it once. best I could tell was inside the heatsink area where Q777 is. Any suggestions on what might have caused the arcing would be greatly appreciated. PRT anode connections look ok. Heatsinks service pack installed already. Thanks!
my tv keeps flashing in and out of picture on all channels how do i fix its keeps flahing on the...
(More)
my tv keeps flashing in and out of picture on all channels how do i fix its keeps flahing on the standby/timer light under the main power on the tv and my rm-y902 remote wont give me a tv code
The color in my picture is a green or yellow tint. I do not have hardly any white in the picture....
(More)
The color in my picture is a green or yellow tint. I do not have hardly any white in the picture. Have tried to manually set the picture, but still do not get a good picture. Can I just replace a lamp or is it more complicated.
