the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Sounds like a bad print job stuck in a print spooler. Turn off copier. Go around to all computers that print to it and open the print queue. delete all print jobs. reboot each PC. Power up copier and see if it clears
The printer top cover is open, or there may be something wrong
with the print cartridge.
Solution
Close the printer
top cover.
If the PRINT CARTRIDGE light continues
to blink, continue with the following steps:
Open the top cover. The
print cartridge cradle will move and then stop.
Locate the yellow arrow on the top of
the print cartridge cradle. The yellow arrow points to a drawing of a
cartridge that represents a symptom. Perform the task associated with
that symptom.
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
The print cartridge is
empty or missing.
The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
