The adjustment screws/nuts should be located either on the top of the headlamp assembly,
behind the headlamp assembly, or near the frame rail by the radiator
support.
You will have vertical adjustment screws for each independent beam
(separate highs and separate lows, but will be same screw if highs and
lows are the same bulb). You may also have additional horizontal
adjustment screws as well
Park
your car on a level ground 30 feet from a wall and measure the height
from the ground to the bulb and mark on a wall (do this for highs beams
and low beams if the bulbs are separate, if highs and lows are the same
bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then
aim the brightest part or cutoff part just below the mark on the wall.
If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
There are two screws just behind the headlamp under the hood. Park in front of your garage door, turn on the lights, and adjust to slightly right. have fun.
SOURCE: how do i adjust the timing on a 1995 Chevy Blazer
Get a timing light, and start the engine. Point the light at the crankshaft dampener. There should be marks on the dampener and a gauge thing attached to the block. You advance or ****** the distributor until the lines are lined up. I would also suggest getting a Haynes manual from auto zone I hope this helps please rate this thank you
SOURCE: "Changing Transmission Filter"+1995 Chevy Blazer
Please click on this link:
http://www.autozone.com/addVehicleId,1996801/initialAction,repairGuide/shopping/repairGuide.htm?pageId=0900c152800c0018
Good luck...
SOURCE: how to adjust headlights on 1995 chevy blazer
park the truck about 10 feet from a wall. I have allways liked to use a garage door.now pop the hood .on each headlight. there is a screw to move up and down left and right.
SOURCE: 1995 chevy blazer won't go into park. everything
I think the linkage is out of adjustment or posiibly the park pin is broken in the transmission.
It could be any of these two only. Check for it.
Do let me know if it helped.
Thanks
Kanu
Testimonial: "please let me know where to look for linkage cable adjust and how do i do it? greatly appreciated! thanks alot!"
SOURCE: how do you adjust the headlights on a 1997 chevy
support.
Park
