Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Xbox 360 screen freezes in the middle of a game at random
By jvfalcons on Nov 11, 2007
ever since i got halo 3 and updated it my xbox has been freezing randomly
Clarification Request
Posted by sonpmo on May 05, 2009
Solution Link . . . www.MicrosoftXbox360Console.com.
Same Problem
May 16, 2009
-   my 360 has red-ringed before, got it to work and fixed it myself, then it worked fine for like a week, and by the way i have a fan mod on it that allows both fans to run full bore (and i havent had any problems with it for the past 6 months just until about a week ago) and my 360 will work for a while then it will freeze for no reason- it wont red ring either and it just keeps freezing no red ringing, so i overheat it cool it down, works for a while, freezes, repeat process, the thing doesnt ever red-ring tho, i need help -   Guest
Mar 23, 2009
-   I was playing NFS: Prostreet, when suddenly during the loading screen the games freezes. It does this in the same spot no matter how many times you turn the console on/off and try starting over. any thoughts? -   Guest
Feb 27, 2009
-   When I am playing a game on my Xbox 360 my screen freezes and the only way to get out of it is to turn it off then turn it back on. It does it about every ten minutes in does anyone know what is wrong? -   Guest
Oct 11, 2008
-   it goes for a bout an hour and hen is just ******* freezes! -   Guest
Sep 28, 2008
-   freezes in the middle of a game at random -   Guest
Best Solution
posted on Dec 18, 2007
Very Helpful)
biomed616
Rank: Wiz  Microsoft Expert
Rating: 84%, 118 votes
There are two possible solutions to this issue. One the data that you downloaded either got corrupted during transfer somehow or during a resent save. You should delete all the iformation off your hard drive and start fresh. If this doesnt work try takeing off your hard drive and playing Halo3 if it deosnt freeze you will need to either try the delete method or get a new HD.
If this doesnt solve your issue then it is very possible that your system is headed for the red rings of death. My system was fried after i had played assasins creed. It would freeze up and create this checker pattern on my back ground my system shortly after went red ring.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 02, 2008
Helpful)
Trublshooter
Rank: Apprentice
Rating: 88%, 2 votes
Well on Oct 31, yes Halloween My sons XBox 360 started freezing up randomly in Halo 3. All day after a few minutes of play. Then trying Hard boot Game would freeze on on logo screen. Tryed different disk would still have problem. Boot without a disk boots ok. Tryed running demo games on line without using disk. Same thing. Unplug and repluged. Clean out cache same thing. The Next morning I turned on Xbox 360 to check status freezed on boot at logo screen, Almost gave up till my wife suggested to check memory. Had 2 gbs left of a 20 gb hard drive. So We deleted demos and other junk to get more memory. Then we cleaned cache again which clears out upgrades and ...well guess what It worked. When we booted halo 3 upgrade loaded again and played game all day and no problems since. Not quite sure if it was just a bad upgrade ....or download...or lack of memory but all is well. hope this might help others with this random freeze problem with no error code. good luck!
Was this helpful?
Yes
No
Solution #3
posted on Jun 06, 2009
Not Rated)
Trblshter
Rank: Apprentice
Rating: 0%, 0 votes
Xbox seems to be freezing up no red rings just random freezing. I noticed a whining sound coming from the brick ( power supply ) and air was not moving through. The power supply seemed as if it was also running hotter then usually. So I stuck it in the freezer for about 20 minutes. Then plugged it back in I hard what sounded like the fan breaking free. Bingo! Works great! worked for months It stuck one more time, did the same procedure, works great no problem since. I believe a lot of these xbox problems are do to the power supply. When they over heat there is no fault indication especially when the fan jams in the power supply. Hope this helps. Good Luck
Trublshooter
Was this helpful?
Yes
No
Solution #4
posted on May 19, 2009
Not Rated)
meyetom
Rank: Master
Rating: 77%, 33 votes
Try this link . . . www.microsoft.com/Xbox360Console
To find your best solution.
9
Was this helpful?
Yes
No
Solution #5
posted on Aug 05, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
get a ps3!
Solution #6
posted on May 19, 2008
Not Rated)
Sharper1106
Rank: Guru  Microsoft Expert
Rating: 87%, 53 votes
does it only do it for halo 3? you might have just happen to have a problem starting around the time you updated
sounds like the the processor is over heating and its causing the system to shut down before it burned up the board. basicly your thermal paste between your processor and the heatsink isnt doing its job. there could be a crack on it might have just degraded over time.
this can cause the system to freeze or see things ont he screen. it needs to be repaired before more issues happen.
united.gamez@gmail.com for help
Was this helpful?
Yes
No
Solution #7
posted on Apr 26, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
awesome!
Solution #8
posted on Apr 25, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
try blowing into pieces with m80;s
Solution #9
posted on Apr 02, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
hi my sons xbox 360 kept freezing so we unplugged it and moved it out of the cabinet and it worked as if it was over heating before
Solution #10
posted on Feb 11, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
how do you deleate information form hard drive
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
I have an open tray error on my xbox and the warrant is up, what is the best way to fix it?
Answer
My X-box won't download mature demos or games no matter what I change in family settings.
Answer
I change my password in facebook but when i log in i put my new password then i cant open my new... (More)
Answer
When I turned on my xbox 360 today it froze before it got to the dash board. This is the first time... (More)
Answer
Hi. Iam looking for someone dependable to fix my sons xbox 360. One red light is on in the lower... (More)
19 Other Users Have The Same Problem - Continued
Comment by Eksacco, posted on Aug 24, 2008
I turn on my xbox and it will begin to play then will freeze happens at different time and i dont know why
Comment by shiraz93, posted on Aug 05, 2008
My console freezes at the stat up and some times during the game and no message comes
Comment by Guest, posted on May 17, 2008
my xbox screen when i put the game on after loading when nearly starting
Comment by jake022, posted on May 13, 2008
i play elder scrolls oblivion and it makes a loud squeak and the game freezes so i reset it and then itll work again. im really starting to doubt microsoft....
Comment by djeionnation, posted on Jan 09, 2008
last sunday, i played halo 3 and the gane started freezing. Now, the freezing is frequent, revealing a checker pattern on the screen. i discovered the system is freezing and not so much the game. the last thing i wanna do is to have to spend $280 to get a new system. How can i fix the problem for good?
Comment by Guest, posted on Dec 25, 2007
The screen has red squares going across it. It just freezes randomly. I won't even go on the game.
freezes with every game that is played
Comment by jcndjarrett, posted on Dec 23, 2007
same with me i have madden 08 and assassins creed and both games freez in the middle of the game microsoft is starting to make me upset
Comment by Guest, posted on Dec 23, 2007
when i play call of duty 4 at a random time my x box just stops.
Comment by Guest, posted on Dec 14, 2007
Me 2!!
My Madden 08 football game freezes in the middle of a game. i can't tell you how many times i've had to restart the game. I purchased another game, but it still does the same thing. my system plays my other games just fine, it freezes only on Madden 08. Can any one help me?
Comment by Guest, posted on Dec 02, 2007
me too
Comment by Guest, posted on Nov 23, 2007
game freezes during gameplay
Comment by Guest, posted on Nov 11, 2007
i have the same freaking problem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
