Home | Samsung | LN-T4061F 40 in. HDTV LCD Television | . Clicks back and for...
Samsung LN-T4061F 40 in. HDTV LCD Television
Problem for Samsung LN-T4061F 40 in. HDTV LCD Television
. Clicks back and forth for about 2-4 minutes then comes on
By soopergooman on Jul 05, 2009
Mine is just starting to do it. if I leave my tv on will it hasten this or not? I am going to nip it in the **** by going to the place I bought it and tell them what I just read here. Maybe it won't take long. Clicks back and forth for about 2-4 minutes then comes on.
put this in my bookmarks.
Best Solution
posted on Sep 12, 2009
Very Helpful)
toddthetvmd
Rank: Guru
Rating: 93%, 18 votes
NOTE the power supply operates at 13.4 volts. The 10volt caps. should be replaced with 16volt or higher. Or you will have the same problem again in about 9-14 months. I repair about 4-6 of these a week. And it seems to be any brand and not just Samsung.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 02, 2009
Very Helpful)
mike0725
Rank: Guide
Rating: 100%, 6 votes
simple fix: http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/
Was this helpful?
Yes
No
Solution #3
posted on Aug 14, 2009
Very Helpful)
Tumwario
Rank: Apprentice
Rating: 100%, 3 votes
Check capacitors on top right corner of power supply. Mine had two 2200uF 10Volt capacitors bulging at the top, one was leaking. I replaced these and the problem is gone. You can order the capacitors on ebay. Board had two 2200uF 10volt caps and three 1000uF 25volt caps, all in the top right corner.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Samsung LN-T4061F 40 in. HDTV
Questions and Unsolved Problems for Samsung LN-T4061F 40 in. HDTV
Do you recommend Samsung LN-T4061F 40 in. HDTV LCD Television?
Answer
Answer
samsung lnt4061f there is a slight shadow of what looks to be about 3 inches wide and about a foot... (More)
Answer
Our samsung LN-T4065F works for awhile then the screen starts blinking. there is no set pattern to... (More)
Answer
LN-4061F: There is a red horizontal box burned into the middle of the screen. TV has never been left... (More)
Answer
early in the morning after tv has been off all night, when you turn it own, the red light flashes... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung LN-T4061F 40 in. HDTV...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
