Can u hook up the rabbit TV to your TV using USB in the back of your tv
I don't think you can plug it into the back of your TV. It runs off your computer and I do know there is a way to connect your computer to your TV wirelessly, and watch that way. The second option is getting an HDMI cord (theyre cheap and can be found at Walmart) and hooking the two up. Should work this way. You can visit RabbitTVSupport.com for more info on setup and installation.
SOURCE: rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
