Brinkmann 815-3786-0 Turkey Fryer Logo
A
Anonymous Posted on Oct 12, 2014
<!-- from fixya rte -->Cooking time for 4.1 kg turkey - Brinkmann 815-3786-0 Turkey Fryer
3answers
How long do you cook 21 pound turkey
https://www.google.com/search?q=how+long+do+you+cook+a+21+pound+turkey&oq=how+long+do+you+cook+a+21+pound+turkey&aqs=chrome..69i57j0l5.8428j0j7&sourceid=chrome&ie=UTF-8
How to Cook a 21.5-Pound Turkey at 325 Degrees Fahrenheit ...
https://www.livestrong.com > Food and Drink
Nov 20, 2017 - Expect it to take 4.5 to 5 hours to cook a 21.5-pound turkey at 325 degrees Fahrenheit -- if your turkey is unstuffed. If it's full of your favorite stuffing, add at least 15 minutes to the total cooking time.
This table from the USDA is based on a 325°F oven, and a fully defrosted or fresh bird. (For an unstuffed bird, we're talking roughly 15 minutes per pound.) If you want to cook a frozen turkey, it will take at least 50 percent longer than the recommended times.
Nov 22, 2018 • Cooking
Roasting times for a turkey
hi cathy.
For a standard turkey that's around 6kg/13lb, the cooking time will be around 4 hours. It's best to calculate your cooking time at 40 minutes per kg or 20 minutes per lb to get the most accurate time.
Roast timer ' BBC Good Food
https://www.bbcgoodfood.com/howto/tools/roast-timer
Roasting times for turkey Google Search
What power level should i when cooking 16 pound turkey?
Turkey Farmers of Canada recommends cooking a whole turkey to an internal temperature of 170°F (77°C) in the middle and 180°F (82°C) in the thigh. When roasting, any stuffing placed in the cavity of the bird should reach an internal temperature of at least 165°F (74°C). Let the bird stand for 20 minutes before carving.
Cooking Times and Temperatures ' Canadian Turkey
https://www.canadianturkey.ca/wholebird/cooking-times-and-temperatures/ https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=turkey+cooking+times+and+temperatures
How long to cook a 19 pound turkey
Cooking times will differ depending on whether your bird was purchased fresh or frozen. Plan on 20 minutes per pound in a 350 degree F oven for a defrosted turkey and 10 to 15 minutes per pound for fresh. 4. A turkey will cook more evenly if it is not densely stuffed.
Best Turkey Cooking Tips : Food Network
www.foodnetwork.com/holidays-and-parties/articles/top-turkey-tips.html https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=How+long+to+cook+a+19+pound+turkey
Nov 22, 2016 • Grilling
How long can aturkey be keot frozen before cooking
Hi rollande laframboise
I have kept turkeys frozen for 4 years, and cooked them and they were as good as fresh turkey,as long as the turkey is properly vacuumed packed 3 to 4 yrs is not an unreasonable time to keep the turkey...if not properly vacuum packed, cook within 3 months or it may get "freezer burned"...dried out and tastes "funny" (not good).
Please take time to rate me
Bud
What temp for turkey done ?
Always use an oven bag is used to promote even cooking.
Microwave on MEDIUM (50% power) for 7 to 9 minutes per pound rotating dish every 15 minutes. Not recommended for turkey over 12 pounds
Use an instant-read thermometer after cooking. Turkey is done when thermometer reads 180 degrees to 185 degrees F for whole turkey or 170 degrees to 175 degrees F for turkey breast. Insert thermometer through **** in oven bag into inner thigh for whole turkey or into thickest part of breast for turkey breast.
For easy slicing, let stand 10 minutes after removing from microwave oven. To open, carefully cut or **** top of oven bag. NOTE Microwave directions were tested in 600 to 700-watt microwaves. Higher or lower wattage ovens may need adjustment in cooking times.
4helpful
I do not have the book and need to know if I am supposed to pour liquid in the bottom of the roaster when I start the turkey.
No, you never put water between the roaster and the cooking pan/ cookwell/ insert, it actually interferes with the cooking. You can put a little water in the bottom right under the turkey, but the roaster cooks very moist and this is really not necessary.
Check the fit- you need about an inch all around including the top to get good cooking. Any place it touches the sides it will tend to overcook.
The Rival manual suggested 375 for pre basted or 350 for fresh 9-14 minutes per pound. In my experience this is too hot. I use 325 for 4 to 4 3/4 hours at 325 for an 18 pound turkey; a 21 pounder takes about 35-45 minutes more. The USDA now uses 165 as the end point temp (down quite a bit from a few years ago), but if you stuff, that has to be in the middle of the stuffing, and the turkey will overcook somewhat while it gets there. All experts agree that turkeys cook better and safer if unstuffed, so considering that you will have to make an extra pan of stuffing to have it for everyone, you would be well advised to cook your turkey unstuffed and use some of the drippings to flavor the pan of stuffing while the turkey rests.
Left my instruction book at home in NC
The formula for calculating turkey cooking time is 3 minutes per pound, then add 5 minutes to total cooking time, rounding to nearest minute: 13.86 lbs. x 3 mins           41.58 mins Plus 5 minutes                + 5.00 mins                                       =46.58 mins Total cooking time             47.00 mins.
Insert cooking thermometer into the deepest part of turkey and make sure an internal temp of 180 F is reached.
Top Brinkmann Kitchen Appliances - Others Experts
john h
Are you a Brinkmann Kitchen Appliances - Other Expert? Answer questions, earn points and help others
