I have a Dometic fridge in my 2005 Lexington motorhome. When I try to start my fridge on auto the check light stays off for a few minuts and then comes on and the fridge will not cool. The last time I used the motorhome was about three weeks ago and the fridge worked fine. I know the motorhome is plugged into a live 110 volt recept. I don't know if this matters but the LP tank is on empty. I had about 1/4 tank of LP when I parked the motorhome and as I said the tank is now empty. The fridge has been set on auto all this time and the gas button is pushed in on the control panel as it should be to run on auto. Please help me if you can. Thank's
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
the fridge freezes everything! even the stuff towards the bottom of the fridge. Milk, fruit,...
(More)
the fridge freezes everything! even the stuff towards the bottom of the fridge. Milk, fruit, veggies...no chance. Frozen. Help a camper moron! It says climate control, but my climate is out of control! help!
My Dometic RV fridge RM 2652 seems to get too cold. The produce in the fridge get frozen no matter...
(More)
My Dometic RV fridge RM 2652 seems to get too cold. The produce in the fridge get frozen no matter where in the fridge it is located. Is there any way to adjust the temperature? Does the Climate Control switch have anything to do with the temperature control?
Have dometic fridge in rv.......new in 2007 all of sudden won't run on electric. Gas fine... but not...
(More)
Have dometic fridge in rv.......new in 2007 all of sudden won't run on electric. Gas fine... but not 12 or 110
My RV Refrig is auto/gas...in the auto mode and plugged into electric it is trying to use...
(More)
My RV Refrig is auto/gas...in the auto mode and plugged into electric it is trying to use propane...also the pilot is taking 10+ clicks to light. Is there something I can do to stop both of these problems?
