Home | Toshiba | SD-4000 | Bad Disc Error Message
Toshiba SD-4000
Problem for Toshiba SD-4000
By yeager_saman on Jul 05, 2009
DVD Player reports "bad disc" on every dvd I have tried (tried about half a dozen). Clearly at this point it appears to be the player and not the disc. Any solutions? Or is my assumption right - do I need to replace it?
Best Solution
posted on Jul 05, 2009
Helpful)
MeccaTronix
Rank: Guru
Rating: 85%, 103 votes
The laser diodes which read the disc weaken over time and the lens can become dirty. Remove the case and you will see the 4mm dia. lens on the assembly rise up to read the disc when inserted. Eject the disc and lightly wipe the lens clean with a cellulose acetate Q tip or head cleaning cloth with just a small amount of disc/optic/lens cleaner. Try playing the DVD. If it will not read any discs then the laser diodes are to weak to read or there is a malfunction in the digital signal processing board. Unless it is under warranty, you will need another unit.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Toshiba SD-4000
Questions and Unsolved Problems for Toshiba SD-4000
Do you recommend Toshiba SD-4000?
Answer
Answer
why does dvd player freeze? I have disks with very little visable scratches, and still get tracks... (More)
Answer
why do dvd players freeze? I play good disks, no scratches, and still get tracks that freeze.
Answer
My tv went black and now i can't turn off the DVD player and i can't open it.
Answer
hello my problem is with the regions of this dvd please if is posible i need the code for this dvd
Answer
dvd don't turn, error "bad"
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba SD-4000:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
