Home | Amplifiers and Preamps | I have 2 mono Power Amp...
Problem for Amplifiers and Preamps
Generic problem for all Amplifiers and Preamps
I have 2 mono Power Amps that were des...
By bobjan1 on Jul 05, 2009
I have 2 mono Power Amps that were designed and built for me about 30 years ago. They have been in storage for about 12 years and I just got them out to test them. They were rated at 400 Watts into 8 ohms. When I tested them, one worked perfectly bot the other one produces no sound at all. I tried each one through the same channel of the preamp with the same wires to elliminate that as a cause. I read the voltage just before it goes into the circuit boards and both amps mathched, so the power supply seems to be working fine. I checked all fuses and all have continuity. What might cause no sound at all? These were really nice sounding amps and I'd love to have them both working again as one without the other makes them useless. They were originally designed and built by my uncle (a DIY audiofile), but he is no longer alive to help. I remember that the transisters he used were called Mosfets. They are very large and each amp has 12. They say Motorola on them and I remember him waiting a long time to get them. Thanks
Best Solution
posted on Jul 05, 2009
Helpful)
Abrsvcs
Rank: Guru  Home Audio  Expert
Rating: 88%, 1774 votes
Since this is a custom design, there is little we can do without seeing the unit directly. This unit should be brought to an audio repair shop. Ask for an estimate. I doubt that this will be a major problem as most designs are similar in many respects. There are a number of reasons for no sound at all. Without seeing the design and taking voltage measurements while on, there is little we can do. The good thing is that you have a working design available as well. That will allow a good tech to A/B the units to assist in understanding the design.
Good luck.
Dan
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Amplifiers and Preamps
Questions and Unsolved Problems for Amplifiers and Preamps
Answer
The school where I work has a set of Numark m-40e speakers/amp. There is no output from the... (More)
Answer
Hi, I have a NAD 3020 and usable volume has gone. You can still hear it really quietly even with the... (More)
Answer
I need a user manual for a Soundlab G097 amplifier
Answer
How can I hook up 4 microphones using the terminal strip? There are no jacks just the 3 wires. Model... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Amplifiers and Preamps:
Top Amplifier and Preamp Experts
Rank: Guru Guru
Solutions: 1459
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Amplifier and Preamp Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
