SOURCE: Stihl gas powered cut off
It sure sounds like a bearing gone bad or one or 2 of the cap screws at the blade end have come lose or the cap screw closest to user end is stripped.
SOURCE: Ts420 stihl cut off saw
the jets in the carburetor need to be cleaned out very well to operate this engine
the holes in the jets are very small and clog up easily with in a year or two
SOURCE: Hi, My Stihl TS400 with 14"
Racing on a 2 cycle engine is usually a sign of a lean condition. It could be caused by a few different things including a bad crank seal or a torn intake manifold as some are made out of rubber. I would remove the cutter arm then pull the muffler to inspect the cylinder and piston. If they are scored it will be a costly repair.
