Go to "ctrl/panel", then "add/remove programs", and find "webroot spareware", click on "remove" on the right side of the listing. This should remove it.
DOWNLOAD IOLO SYSTEM MECHANIC AND YOU CAN USE IT FOR REMOVING THE PROBLEMATIC SOFTWARE
Comments:
Jul 11, 2009
- another way u can try is
To uninstall Spy Sweeper :: let Microsoft Windows uninstall the software automatically.
1.clicking on the Start Button
2. Select Control Panel
3. Select Add and Remove Programs.
Occasionally this method will not work, and produce an error about not
being able to uninstall the software. If this happens right click on
the Spy Sweeper icon on the right hand side of the toolbar where the
clock is located and select exit This will shut down the Spy Sweeper program. Next press ctrl + alt + delete which will open the Task Manager. Click on the Processes tab. Search for spysweeper.exe. If this process is running click on it then select end process. Repeat this step to search for and close the process WRSSSDK.exe. After this is done Spy Sweeper should be able to be removed by using Add/Remove Programs
how do i turn the virus sweep on i just bot webroot antivirus and spysweeper and wont let do...
(More)
how do i turn the virus sweep on i just bot webroot antivirus and spysweeper and wont let do anything
I have a connection error in Webroot that says the EIS Engine has failed. Do I need to uninstall and...
(More)
I have a connection error in Webroot that says the EIS Engine has failed. Do I need to uninstall and reinstall Webroot?
