Hello friend, thank you for your post!
In order to provide you with accurate information could I please get your model and serial number? Each refrigerator has different sets of instructions for leveling doors. Typically you can locate your serial tag (which lists your model number) on the inside wall of the fresh food side of your refrigerator. I have included a link to search for any available manuals. I hope this is helpful. -Matt
Frigidaire Product Manuals
SOURCE: refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
SOURCE: FRIGIDAIRE TOP MOUNT REFRIGERATOR
If the model FRT18IS6CQG is correct your refrigerator has a defrost thermostat inside the fresh food section where the controls are. Need you to turn it clockwise until the refrigerator stops running. This puts the fridge in manual defrost. About 20 minutes later it should come back on without your help. If not we need to replace the timer. Let me know Sea Breeze
SOURCE: fridge door is lower then freezer door
The #1 cause for this problem: The floor beneath the fridge is uneven, causing the refrigerator "box" to be out of square. Adjust the levelers on the fridge bottom to compensate for the uneven floor. That should do it.
SOURCE: FPE26VWCW1 Frigidaire side by side. No power to
Removed the door switch. Tested OK. Removed fan; tested OK. Put back together and it worked. However, the fan for a moment had a sound like loose bearings, so I ordered a new one.
SOURCE: Describe your frigidaire refrigerators frs26r4cq0
Your condenser fan probably is not running. It's underneath with the compressor. It should be running when the compressor runs. You can place a fan on the floor blowing on the condenser coils till you get it fixed. The fan should spin freely. Test the fan motor for continuity using a multitester. Set the multitester to the ohms setting X10. Place a probe on each terminal. The multitester should display a reading approximately mid-way between infinity and zero ohms. If the motor does not pass this test, it should be replaced. You don't need to test the middle one if you have one.
Testimonial: "Putting a fan on the floor is working! Will have to get a multitester to check the rest--guess Lowe's will have one in the electrical dept? Thanks!"
Thank you for your inquiry, Leland Dodd!
I see that you are having difficulty in raising the level on your Frigidaire refrigerator, FGHC2331PF. I have reviewed your manual and there are two types of adjustment for either front rollers or lower hinge. If you are having issues with adjusting the doors or leveling your refrigerator I would recommend having a professional technician out to properly level your refrigerator. Best of luck! -Matt
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
