Microwave Ovens Logo
A
Anonymous Posted on Oct 11, 2014
I NEED TO KNOW HOW TO WORK THE OVEN
I DON'T KNOW HOW TO USE THE OVEN
Kolbrun Gunnarsdottir
Level 3:
  • Magic Chef Master 1,228 Answers
  • Posted on Feb 01, 2015
Magic Chef Master
Level 3:
Answers
1228
Questions
6
Helped
277631
Points
3915
Good evening
if you can not find the manual, try this and find the manual you need.
kolbrun
Free User Manuals and Owners Guides ManualsOnline com
1helpful
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
1helpful
I want whirlpool oven mechanic in kakinada
see the details and proceed according. fix it. God bless you
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Maytag microwave keypad
see this causes and fix it. God bless you
Troubleshoot maytag keypad control board
My 7 years old dacor pmor30s microwave oven sometimes works ok, but sometimes it does not heat the food. I don't know why. Do you have any idea?
The most probable cause would be a problem with one of the door switches. When it is not working shake the door up and down and hit "start" again. If that made it work, you would need to test the switches for proper operation.
Loss of power
There would not be a reset button, but a hard reset can be done by unplugging it for a minute or so, then plugging it back in.
If that doesn't work, chances are you have a fuse blown in the microwave.
It's usually behind the grille, which is held in place by two screws.
Let us know what you find.
Top Magic Chef Microwave Ovens Experts
Jerry Naidoo
NOEL
NOEL
vince
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
