Question about Mitsubishi WD Televison & Video
How to reset tv after a storm
The satellite went out during a storm, unplugged unit plugged back in now only snow
    Scholar:
    New Friend:
  • 85 Answers
Does the satellite receiver power up? Usually they go through a test sequence when trying to reconnect, i.e., there is some picture output to the TV even when a satellite is unavailable. Did the input on the TV get changed? Try cycling through all the inputs. Do you have any other video devices, like a BlueRay or DVD player? Do they work? Divide and conquer, figure out what does work, then look deeper into what does not.
Posted on Oct 11, 2014
SOURCE:
How to reset a Mitsubishi wd62628
If you're talking about the television, theres a reset (use a paperclip) behind the front panel.
Oct 11, 2014 | Cars & Trucks
Hitachi 46w500 went off tonight during storms, low voltage, wont turn back on
There might be a failure on the power supply or horizontal section of the TV even if you see some light inside the TV. Some of the voltages could be missing and that is why the TV fails to power up.
If you know how to use a multimeter, you could check all the fuses from your power supply.
Unplug your TV from the main AC line if you intend to do it yourself.
You will know how much you can do or it might safer to contact a tech.
Let me know if you need further assistance
Jun 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Wall ac in off position plug in surge protector blows instantly
It may be possible the it has fried the surge protected internally causing it to short out or blow when plugging in. I would try using another surge protected if you have one or if possible replace the cord going to the unit with a new one and see what happens. Also possible that the outlet your using went bad during the storm as well. Don't know 100% but should be a couple tips to help get you going.
Aug 19, 2012 | Video Game Consoles & Games
No picture, but sound
tried to hooked up with an air antenna. if you can not get any channel and just a white raster or snow, it could be the tuner get fried.
Jul 22, 2012 | Sony KV-32S45 32" TV
Don't know how to program TV since went off during storm I have a 37" TV purchased at Future Shop in March. Can't seem to reprogram it as it went off after a storm. Tried unplugging the...
Tries go into tv menu goto SETUP.Go down to Ch.enter pick AIR and enter to scanning.After finish scanning should have all the free DTV broacasting channels again.
Jun 10, 2011 | LG 37LG50 37 in. LCD HDTV
Satellite dishes wen down during storm. Attempting to find signal. SDHBH box is unresponsive. Is there a hard reset procedure?
Yes,unplug,replug the box back like about an hour later.The box,will reboot and updated it software.The incomming broadcasting signal should be back.If not storm,did more damages to the LB reciever connected on the dish itself.Must call Dish Network to check it out,might have to replace it.
Mar 21, 2011 | Hughes SDHBH DirecTV DTV Receiver
TV won't work after storm
ok lets try this hit the power button on the DVD player some go into stand by mode and when power is interrupted you have to push the button manually also reset the surge protector next get a lamp that you know works and unplug the tv and plug the lamp into the socket where the TV was plugged into turn on the lamp, does it turn on? yes then something wrong with TV again may have been in stand by mode plug back in and try pushing the power switch on make sure the TV if it has a remote is on the right im put to get a picture say like a satellite or cable or DVD player. hope this helps.
May 29, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Lost signal from the satellite
Signal Fade And Loss ~ Important, especially during winter!
Keep in mind that satellite broadcasts occur directly from fixed satellites in space to users. UPLINKS TO that satellite can happen from almost anywhere in the world! This includes broadcasts from remote studios, satellite vans and trucks.
Even signals from the main providing studios are susceptible to weather conditons even tho they have huge, high-gain transmitting dishes!
Weather is a major factor for both the uplinks and downlinks! Storm clouds can block the signals anywhere in the signal path(s). Rain clouds do too ~ even if it's not raining yet. Water-laden clouds make some of the BEST signal attenuators.
So one may have a gorgeous day in San Diego (let's say), but storms back east could trash satellite reception at his location and potentially everywhere else!
As you know, weather conditions all over the US are changing constantly with many severe storms occurring this past week and during any winter. In fact this week there was total signal loss on several satellites and I suspect storms back east were a big factor.
So it could have just been issues of timing for you. The UPLINK had intermittent problems with signal paths semi-crippled by weather... YOUR weather was CLEAR, but your reception was far from problem free ~ only because of weather problems elsewhere.
If you see intermittent satellite reception do check out the weather... especially back east.
Hope this helps!
Feb 01, 2009 | DISH Network Televison & Video
Tv turns on and then off
Good Day, ruschracing;
Storm? The first thing you should do is unplug the TV from the wall for 3 to 6 minutes (reset), then plug back into wall.
If that does not help, then you should call an authorized service center to give you an estimate for the repairs. OR call your home owners insurance company.
Good Luck, big IRISH.
Jul 25, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
171 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
