Question about Agfa SnapScan E25 Flatbed Scanner
Drivers for Vista
I've upgraded to Windows Vista. It comes up as incapatible software problem.
Please, can you let me know of a solution.
Thanks Phil S
  • 2,985 Answers
Re: Drivers for Vista
With the Computer.
Go to Start/programs/accessories/system Tools/Compatibility and attempt to reset the computer to the Windows mode the Scanner was made for.
Be aware however that Scanners made for use with Win 95/98/ME operate under DOS commands and 2000/XP/Vista work on the NTFS system so there is a hardware not software problem.
You will I feel wind up buying a Vista Compatible Scanner
Posted on Dec 27, 2007
0 characters
3 Points
I downloaded the drivers to my vista computer but keep getting an "unable to select Twain Source error".
The drivers for your Canon CanoScan 4200F Flatbed Scanner available are for Windows 7 64bit, Windows Vista 64bit, Windows ME and Windows 98. Is your Windows Vista a 64bit version? You might want to upgrade your Windows Vista from 32bit to 64bit. Always remember, the softwares and drivers are limited to manufacturer's releases.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
TIPS: Is your computer slow? This might help
(for Windows only)
Feb 21, 2011 | Canon CanoScan 4200F Flatbed Scanner
Download for printer with Vista
Click on the Link to download drivers for Vista.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, PREM
Apr 06, 2009 | Scanners
Old scanner x Windows Vista
U'r Installation  disket might  not work
even  if u could  get the  data in it
u will have to install the drivers for this scanner
if  U  could  provide me with the Scaneer model i could  find  out the driver and post the lin so that u could download it.
Nov 04, 2008 | Scanners
HP ScanJet 3200C
Hi! I need drivers for old scaner HP ScanJey 3200C for Windows Vista.
Sep 07, 2008 | HP ScanJet 3200C Flatbed Scanner
Acerscan 620U upgrade to Vista
Go to the Acer website and enter your particular model and you can download the official drivers from there....
Sep 05, 2008 | Acer ScanPrisa 640U Flatbed Scanner
Problem regarding installing HP scanjet 3770
I am using HP scanjet 3770 for the last 1 year. I was runing it on windows XP, but now i have installed Vista on my pc and itis not installing due to the drivers. Kindly help me in getting the software installed on windows vista. From which site i will get the drivers to download...
The specific ero: Parsing error in file C:\Program file\HP\Digital Imaging\bin\hpqscloc\1033.xml
Please Help (Ayúdame)
Apr 22, 2008 | HP Scanjet 3770 Flatbed Scanner
Load the XP drivers and run it in compatibility mode. Or right click on the exe files after unzip and mark in compatibility mode xp. Works fine!!
Dec 16, 2007 | Canon CanoScan N656U Flatbed Scanner
Drivers/software for Umax Astra 3400 scanner
the link above will take you to the drivers you require, it says windows me but also in the comments it says for XP as well.
Dec 06, 2007 | Umax Astra 3400 Flatbed Scanner
Windows Vista
The VueScan program will work, but you have to go into device manager (Right-click "My computer" choose "Manage" select "Device Manager")
In device manager, you will probably see the scanner detected with a yellow triangle. Right-click the scanner and choose "Upgrade Driver" then choose "browse my computer for updated driver" and browse the the "VueScan" folder on your C drive.
Once you do that Vista will update to the VueScan Driver and you'll be ready to go (once you pay the nice folks at VueScan so that your scans don't have watermarks on them)
Sep 01, 2007 | Agfa SnapScan 1212u Flatbed Scanner
Agfa SnapScan E25 Flatbed Scanner Logo
211 people viewed this question
Top Agfa Scanners Experts
Starnley Johnwells
Starnley Johnwells
Are you an Agfa Scanner Expert? Answer questions, earn points and help others
