Home | GE | Profile 26.6 cu. ft. Side-by-Side Ref... | Leak from bottom of fri...
GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Problem for GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with...
Leak from bottom of fridge
By raviarizona on Jul 05, 2009
I have the GE side by side fridge, it has the water dispenser, when I take water the water leaks from the bottom of the fridge, the tubing seems to go from wall to filter and then back down, thats where it is leaking from, I might have to call the GE repairman or open the sheet metal cover and see if the fitting is loose...
Solution #1
posted on Jul 05, 2009
Not Rated)
mcneb
Rank: Guru
Rating: 87%, 162 votes
Two things might be happening. One is the line to the fridge is leaking, this line come thru the floor or wall to the bottom and hooks up to a water valve, it may just need tightening. The other problem is you will have a hose that runs from the filter down in behind the crisper drawers to the bottom and coils up here to hold water for cold use. it then runs thru the bottom pan out to the front, to the bottom door hinge on the freezer side up the door to the dispencer. Check along the hose for a pin hole look at the bottom hinge area first, things bump into it here and can damage the plastic cover.
Was this helpful?
Yes
No
Popular Solutions for GE Profile 26.6 cu. ft.
Questions and Unsolved Problems for GE Profile 26.6 cu. ft.
Do you recommend GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW?
Answer
Answer
shelves and baskets fall down off of supports....seem to be not wide enough in the freezer section
Answer
the refrigerator makes ice but will not dispense it , however It will still dispence water.
Answer
ice maker in GE Profile side by side leaks where the ice cubes are made and causes an ice block... (More)
Answer
nothing working except for the interior lights and flashing "hrs" error code
Answer
At the bottom of the freezer portion of the frig. Water seems to collect and freezes at the bottom.... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile 26.6 cu. ft....:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
