Hi Thomas Nsowa, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Is the refrigerator side staying cold? Why are you worried about it?Hi Thomas Nsowa, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Is the refrigerator side staying cold? Why are you worried about it?
You can't post conmments that contain an email address.
Sounds like one of the fans aren't working. The fans only work when the both doors are shut. Shut one door and use a strong magenet on the magenetic sensor ( located on where the door shuts in between the two doors. Shaped like a lump that sticks out). Put your hand to the back wall of the fridge (or to the fan in the freezer) and see if there is air movement. Is there isn't then its the compartment your in's fan.
If they are both working then it could be your freezers de-ice element not working or your fidge my need to be switched off to defrost
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly. Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater. Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Please :
- Clean up your freezer
- set the thermostat to middle
- check the fan for malfunction
There are many things that cause your freezer work abnormally.
You said, overloaded freezer may have caused fan to go out? Is this possible?
Cleaned dust from compressor and shut off to let it cool down but it is
still not working
Yes It's possible. If the freezer is so packed full where the packages cover the air vents in the rear of the freezer. The freezer and the fridge share the cold air and this is the first think we look for if the fridge is warm and the freezer cold, And the fan works nonstop rather than cycling off and on!
What is the model number and year of your fridge!
Waiting your response. Huuum Please remember to leave a rating!
