I turn on the laptop & this is the message I get:
We apologize for this inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this.
If your computer stopped responding, restarted unexpectedly, or was automatically shut down rto protect your files & folders, choose last know good configureaction to revert to most recent settingins tha worked.
If a previous startup attempt was interupted due to a power failure or because the power or reset button was pressed, or if you aren't sure what caused the problem, choose start windows normally.
(Opitions given to start computer)
Safe Mode
Safe Mode w networking
Safe Mode w/ command promts
Last know good configuration(your most recent settings that worked)
Start Windos Normally
** I have tried all of those opitions. However it still won't start up! I am fed up with it. What can I do? Or Do I need to buy a new part?
What I need it to work so I can get more things done during the day!!!!
Thanks for any help!
Comments:
Jul 05, 2009
- neerajswar- I pressed f8 and got the Windows advanced Options Menu:
(options given)
Safe Mode
Safe Mode w/ networking
Safe Mode w/ Command promt
Enable Boot Logging
Enable VGA Mode
Last known good configuration
Directory Services restore mode
de bugging mode
disable automatic restart on system failure
reboot
return to os choices menu
I don't see anything about Bios and the hard drive.
Jul 05, 2009
(options given)
Safe Mode
Enable Boot Logging
Enable VGA Mode
de bugging mode
reboot
Restart the Laptop and press F8 you will get a option that sayd repair my computer select the option,
If repair mu Computer doesn't work than go to BIOS and check if the Hard drive is detected in BIOS or not and than perform Hard drive test in BIOS there is utility which will allow to perform the test of hardwares.
If Hard drive is detected in BIOS nad Hard drive test passedthan you need to reinstall the windows.
If Hard drive test failed or it is not reflected in Windows than replaced the hard drive and install OS on new hard drive.
my laptop no. is c77tu presaruoc700 compaq not respond for sound system after install windows xp...
(More)
MY LAPTOP NO. IS C77TU PRESARUOC700 COMPAQ NOT RESPOND FOR SOUND SYSTEM AFTER INSTALL WINDOWS XP PLEASE SOLVE SOUND SUSTEM PROBLE.
