See if a PCI or network controller card appears in Device manager first (control panel).
If the computer detects the WIFI card it will be installed or appear with an exclamation point.
Check that first, if the card appears with an exclamation mark, click uninstall.
Download the WIFI card driver from Compaq. Install the driver and restart the computer.
Once the computer restarts, then it should automatically detect the hardware and boom should be working.
If this does not solve the problem (assuming the exclamation point was there) then uninstall the WiFi card again and restart the pc.
This time allow the computer to restart and detect the hardware. Do not click anything on the hardware wizard. Instead run the WiFi card driver software again. Restart pc and hope it works.
If not, let me know and we can try something else.
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS...
(More)
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS your views on these boards as to building your own computer etc?
como conectar los cables de una motherboard Foxconn 45Gm/Cm? H.D.D LED + P LED - P LED RESET SW...
(More)
como conectar los cables de una motherboard Foxconn 45Gm/Cm? H.D.D LED + P LED - P LED RESET SW POWER SW
