My name is Peter, I am a retired Sears Home Services Tech. This could be a serious problem. When your liner cracks, moisture gets into your liner - it freezes and expands cracking the liner.
You need to get a hair dryer . Heat the area. Try to get as much liquid our of the cracked area. Be patient, You need to get a good Silicone water proof sealant. If you do not dry out the insulation material the problem will continue. Please let me know how you
make out. 443-306-1362.
SOURCE: small amt. of water dripping from behind veggie bin
Hi, It sounds like the tank for the fresh water dispenser. Is it coming from the tank on the back wall of the fresh food section?
I can not find the part # but, if this is the source of the leak, I can give other ideas.
Please let me know if I can assist you further.
Vic
SOURCE: Water leaking along back interior to bottom under & over veggie bins
Sounds like the drain to the drip pan is clogged -- maybe with ice.
Defrost water runs down to a drain in the bottom of the fridge and into a pan underneath where it evaporates.
Sounds like the defrost water is not reaching its final destination.
Here's the way the same problem was solved earlier today:
For those who have this problem with this model: The drip pan is in an open space on the back side of the refrigerator. There is a rubber spout that empties into it. But to clear clogs...you must take out the shelves from the freezer, unscrew and remove the back panel on the inside of the freezer. There you will see the water exit. Boiling water cleared it out.
SOURCE: Magic Chef CTB1722 refrigerator leaking water from
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out
with hot water and clorox may help. Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
SOURCE: My whirlpool is leaking water under the
defrost it, remove back panel on freezer side, and unclog small hole where water collects
