Home | Electrolux | Kenmore 24 in. Built-In Dishwasher with 5-l... | The place where u pla...
Electrolux Kenmore 24 in. Built-In Dishwasher with 5-level Precision Direct Water Delivery System Dishwasher
Problem for Electrolux Kenmore 24 in. Built-In Dishwasher with 5-level...
The place where u place the soap won't let all the
By jenncuster on Jul 05, 2009
the place where u place the soap won't let all the soap out why
Solution #1
posted on Jul 05, 2009
Somewhat Helpful)
justaskjoe
Rank: Guru
Rating: 85%, 1868 votes
hello. i can help you.
When the detergent cup doesn't open, check these:
Timer
Bi-metal switch or wax motor
Detergent cup, itself
Timer On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary.
Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards.
The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it.
On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly.
Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door.
Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly
The cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
Was this helpful?
Yes
No
Popular Solutions for Electrolux Kenmore 24 in.
Questions and Unsolved Problems for Electrolux Kenmore 24 in.
Do you recommend Electrolux Kenmore 24 in. Built-In Dishwasher with 5-level Precision Direct Water Delivery System Dishwasher?
Answer
Answer
top spray arm does not rotate, it is mechanically free to rotate
Answer
Dishwasher wont drain . After the cycle is done the water is still in the machine.
Answer
when dishwasher is turned to the start position, water will fill to about six inches and the machine... (More)
Answer
my kenmore 24 in. 15689 built-in dishwasher leaks water through the door base.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Electrolux Kenmore 24 in....:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
