When i turn on my pc initially it will work properly.But after some time it will shutdown.The red led will turn off but not the green one.The fan will also turn off.The pc cannot be restarted.i have to turn off all power supplies to start the pc again.Sometimes the system will not turn on at all.I thought it was a harddisk failure.But the problem still exists with the new harddisk.
hi there,
what about changing your power supply at cpu,disconnect the avr before doing this,disconnect all terminals leads on pc board,cd room and hardisk if you have spare of
power supply or other pc,you can installed to check before buy one,if still shut down whiile power supply was replaced,replace cmos battery,check also your video card and memory card,you can run your windows with out hardisk and cd room just to check if your system is running functionaly.regards
the problem is with yur smps i think.yur turn on button is directly connected with the smps i think.if the smps fails to run yur system will hang.please wipe and dust yur smps completely and see if the system is working.. or else you should change yur SMPS..
I'm building a desktop from scratch. The new motherboard came with a faceplate that has little...
(More)
I'm building a desktop from scratch. The new motherboard came with a faceplate that has little fingers around some the holes. Do those need to be taken off or just bent out of the way?
I work with hand drawn illustrations that I scan as bitmaps and would like to change theminto vector...
(More)
I work with hand drawn illustrations that I scan as bitmaps and would like to change theminto vector based illustrations to colour them in using either illustrator or photoshop. Open paths are a problem while colouring in the illustrations so how would I close open paths on these vectors?
i have a emachines et1161-01 snid#83701753390 and the REG_SZ data value is not set. can you help me...
(More)
i have a emachines et1161-01 snid#83701753390 and the REG_SZ data value is not set. can you help me set the value for this ???
HP Compaq 5311SR Desktop with XP. I changed the power supply but am unsure on which connector...
(More)
HP Compaq 5311SR Desktop with XP. I changed the power supply but am unsure on which connector attaches on the bottom front. I am looking for some kind of chart to verify which number connectors go where. P3, P2, P4, etc.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
