Question about Apple iPod MA446LL/A MP3 Player
Scroll wheel is nonfunctional
The scroll wheel and buttons will not work on my iPod Video
  • 85 Answers
Try to restart the Ipod.
Hold the select button and the menu at the same time until you see the screen go off.
If still does not work then try to enter disk mode and see if it works.
Disk Mode:
Reboot the ipod via Select and menu, right away hold the select and play button and hold until disk mode comes on. Does the wheel work?
If still does not work then reboot the ipod again and let it reboot normal to go back in apple firmware. If all buttons are working and none of the above works, I would assume it is not software related.
Posted on Nov 12, 2007
I can not unlock my ipod and i do not have the primary pc
You may not want everyone to see the content you have stored on your iPod.
Whether it's a private photo, music that might be inappropriate for young ears, confidential information or contacts saved from work, you may need an extra safeguard to keep this information from reaching others.
With the iPod Nano, you can set a password that allows you to lock the unit so that only you
or someone you entrust with the password an view its contents.
And if that password gets into the wrong hands, you can always reset it from your iPod.
Use the click wheel on your iPod Nano to scroll to "Extras" from the main screen.
Press the center button to select the Extras menu.
Scroll down to "Screen Lock" and press the center button.
Scroll to "Reset Combination" and press the center button.
Enter your current password when your iPod asks you to enter your choice of password.
Use the click wheel to scroll through the numbers and the center button to select a number; repeat this to choose the next one, and so on.
Re-enter your new password to verify the change.
You have just set a new password on your iPod Nano.
Aug 01, 2013 | Apple iPod nano
My volumn on my ipod 4th gen is not working and when i go to settings it only shows languages no volumn setting
One of the major warnings Apple includes with all of its iPods is the permanent hearing damage that could occur if you have the volume on your iPod turned up too high.
To help combat the problem, the iPod comes with a feature that allows you to set a maximum volume level that your iPod can be played at that level is controlled by a combination that can keep others namely children from turning the volume up to dangerous levels.
The good news is, if that combination falls into the wrong hands, it can be reset.
Use your iPod's click wheel to scroll down to "Settings."
Press the center button located in the middle of the click wheel to select the settings menu.
Scroll down to "Playback" and press the center button to select it.
Scroll to "Volume Limit" and press the center button to select it.
Use the click wheel to scroll to the first number of the old combination and press the center button to select it.
Repeat this process for all four numbers of the old combination.
Use the click wheel to scroll to where you want the maximum volume to be set and press the center button.
Use the click wheel to scroll to "Lock" and press the center button.
Use the click wheel to enter the first number of the new combination when the message "Enter New Combination" appears on the screen repeat the process for the three remaining numbers.
Once the four numbers have been entered, your iPod's maximum volume will be set and your password will be changed.
hope this helps
Oct 17, 2012 | Apple iPod Audio Players & Recorders
Under settings all it will show me is language there is no volumn setting-my sound is not working correctly
hope this helps
Oct 17, 2012 | Apple iPod nano 4th Generation
I need to change the lanuage from japanese to engish on a ipod and I know absolutely 0 japanese
If you have an iPod nano or Fifth Generation iPod (iPod with video):
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
Select your preferred language from the list.
If you have an older iPod with color display (including iPod photo)
  1. Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
  2. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  3. Scroll up to the third menu item from the bottom one. This should be Language.
  4. Press the Center button to select Language.
  5. Select your preferred language from the list.
If your iPod has a monochrome display (black and white):
  1. Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can restore your iPod back to factory condition and reselect the display language.
Apr 29, 2010 | Audio Players & Recorders
My ipod is frozen. "Connected eject before disconnected."
Hello, if it's still frozen try holding the power button and the center of the scroll wheel, or the power button and the top of the scroll wheel until it restarts, then try re-connecting it again.
Nov 30, 2009 | Apple iPod nano
Ipod nano 8GB doesn`t work
Hold down the middle button and the top of the scroll wheel until you see the apple symbol. Keep holding the middle button then hold down the bottom of the scroll wheel. This will reset the iPod so that it will work. If the scroll wheel is still not working, take it to the place you purchased it or if it is in the area, find a local Apple Store and take it to them. They will be able to assist as well.
Oct 27, 2009 | Apple iPod nano
How to get my language back to english
Select your language.
  7. Select your preferred language from the list.
for more details just click the link below http://support.apple.com/kb/HT1824
rate the solution if it helps. thanks.
Jan 05, 2009 | Apple iPod nano
Wrong language on ipod
This is simple but good to know.
-----John
If that doesn't work go to: http://support.apple.com/kb/HT1824
Nov 24, 2008 | Apple iPod nano
Ipod nano and ipod video 5th generation
First off, simply press the center and menu buttons at the same time to reset the iPod video. That is the common way to fix a frozen iPod.
In regards to the Nano, sounds like the scroll wheel is defective. We would recommend replacing the scroll wheel if a reset does not do the trick.
Rick
EverGreen Electronics
Feb 18, 2008 | Apple iPod MA446LL/A MP3 Player
Scroll ring intermittent / non functioal
I have a similar symptom, that is, apparent loss of scroll ring functionality as homercles1 noted, but in fact the scroll ring functionality gets toggled between horizontal scrolling and vertical scrolling as Rithas has noted. A window that is not wide enough to require horizontal scrolling will give the appearance of loss of scroll ring functionality when the scroll ring is in horizontal scroll mode. Likewise, a window that is not tall enough to require vertical scrolling will give the appearance of loss of scroll ring functionality when the scroll ring is in vertical scroll mode.
Solution that worked for me:
My upper right-hand button is defined as "Allow Horizontal Scroll" and by clicking this button, the scroll ring function toggles between horizontal and vertical scrolling. In fact, what can appear to be a nonfunctional scroll ring in some windows is very useful when moving around in large windows.
Hope this comment will be useful to you.
Nov 20, 2007 | Kensington K64325 Trackball
Apple iPod MA446LL/A MP3 Player Logo
81 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
