In Thomson CTV smps having a problem during start without remote continue blinking stand by continue & +125 o/p DC volt is ok
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continues without any pause, the main board is faulty.
SOURCE: sony kv-32fs10 won't turn on...stand by light blinks continuously
If you have sound when this is happening, this can be an indication that the picture tube is starting to fail. Try the following:
1) Carefully remove the back of the set.
2) Locate the flyback transformer (part with large red wire coming out the top.
3) There should be 2 controls on the back side of the flyback, one marked screen adn the other focus.
4) With the set plugged in and on, try turning the SCREEN control slightly clockwise.
If the picture pops on, then the tube itself is starting to fail and you have sometime to find a replacement.
PLEASE NOTE: There are potentially dangerous high voltages inside te set even when unplugged. DO NOT touch the red wire or the side of the picture tube itself.
Let us know your progress.
Thanks,
Dan
