SOURCE: 94 buick regal grand sport
sounds like the same thing that was wrong with the 94 GS i recently bought. found the crankshaft postion sensor to be bad. it controls your electronic spark timing which would allow it to turn over with out starting.
also does your stall when you are stopped and at idle or while at driving speed or both? mine would stall at idle and driving speeds. Changed that sensor and have not had any more issues with stalling. sensor should cost around $30-$40 dollars at your local autozone, takes about 2 hours to change just need to pull the harmonic balancer pulley (make sure to use the proper tool or you will bend the pulley) and the sensor is behind the pulley. you will gain easier access to doing the maintenace buy removing the passenger front tire and the little splash gaurd directly behind the tire held on by 3 quick release fasteners. hope this helps you out.
SOURCE: How to replace front struts on 1992 Buick Regal
Go to the autozone.com website and register the car. It doesn't cost anything and will give you access to an online repair manual for the car. The steps for replacing the struts for your car can be found there. I checked. Hope this helped and best wishes.
SOURCE: How do I replace a starter in a 2000 Buick regal
The starter is on the underside of the transmission, there are wires feeding the solenoid (remove) 3 starter bolts (remove) pull off transmission/flywheel
SOURCE: '95 Buick Regal GS 3rd brake lights don't come on.
my 02 has 2 nuts in the trunk then it will lift out of the cat walk
SOURCE: how do i change the
Use a spring compressor to clamp the spring down (Be Careful). disconnect strut from lower control arm, and the 3 or 4 bolts under the hood ontop of the strut tower. Remove strut and spring, remove spring from strut (Still Compressed), put spring on new strut (Still Compressed), Install bolts under hood, aka strut tower, reconnect lower control arm, slowly uncompress the spring and make sure it seats properly. Take it an alignment shop to get your front end re-aligned.
