Most problems with TV not turning ON is a power supply related problem. The relay click are a normal process that powers up the circuit boards. Right now the TV is most likely in " Protection Mode ". The TV detected a bad circuit board and it will prevent the TV from fully turning ON. This keeps the other circuit board from being damaged. The power light blinking is a code. If by chance the TV is still under warranty, go that route. If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet. This will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, blinking light codes, test points, and part# lists. Usually, cost under $20.
picture is only coming up on half of the screen on my panasonic plasma tv. The other side of the...
(More)
picture is only coming up on half of the screen on my panasonic plasma tv. The other side of the screen is black.
Tv worked an hour ago now all of a sudden it has a 2inch wide by 12 inches long running verticall...
(More)
Tv worked an hour ago now all of a sudden it has a 2inch wide by 12 inches long running verticall from the middle of the top to halfway down
I can not turn on the TV ,when I try to turn on the power the led beside the power button, blink 12...
(More)
I can not turn on the TV ,when I try to turn on the power the led beside the power button, blink 12 times and wait for while repeat it.
not enough to make the picture unwatchable but annoying enough to make it unpleasant. TV is around 6...
(More)
not enough to make the picture unwatchable but annoying enough to make it unpleasant. TV is around 6 years old and problem just started last month.
