Cars & Trucks Logo
A
Anonymous Posted on Oct 10, 2014
I recently posted I was having hard spots in my
I recently posted I was having hard spots in my steering system on my 1992 Lexus LS400. Aside from the hard spots The power steering was pretty smooth I was told By one of the experts here that I need to replace the rack and Pinion. So I purchased a rebuilt rack and Pinion from Detroit axle. After installation my steering is now stiff i'm wondering if now has my power steering pump going out all of a sudden. Or could it be the solenoid the screws into the rack and Pinion? I do appreciate any answers you might have
robert wales
Level 3:
  • Lexus Master 4,977 Answers
  • Posted on Oct 11, 2014
robert wales
Lexus Master
Level 3:
Answers
4977
Questions
0
Helped
1332579
Points
59541
Make sure all air is bleed out of the system by turning the wheel fully to one side then the other until the air is out of system and fluid level is at the correct level before replacing the solenoid.
1 Related Answer
robert wales
  • 4977 Answers
  • Posted on Sep 20, 2014
SOURCE: The power steering on my 1992 Lexus LS400 has real
this problem indicates a bad steering rack. the bushings in the rack are worn and have caused groves in the housing causing the binding. the only solution is to replace the steering rack. if a problem was the power steering pump it would not get easy when you turn the steering wheel further the problem would be there all the time.
Testimonial: "Thank you Robert for your input I really helps me out I really appreciate you taking time to answer my question"
Will a power steering pump off a 98 lexus es300 work for a 98 lexus ls400?
best ask a steering specialist shop as the engine identification shows a es300 as a 1mz-fe (3.0 ltr) and a ls400 as a 1uz-fe (4.0 ltr)
there may be mounting differences between the engines
I recently just changed the rack and Pinion in my 1992 Lexus LS 400 do to hard spots in the steering. Now my steering extremely stiff. I'm wondering if it has to do with the solenoid that mounts to the...
the steering lines fittings are different sizes it could be the sensor however make sure all the air is bleed out of the system first. to do this with the engine running turn the steering wheel full left and full right until you hear no noise then check the steering fluid level and repeat as needed.
1helpful
The power steering on my 1992 Lexus LS400 has real bad hard dots when I turn rt or left. It gets real stiff & then the hard spot releases if I keep turning the steering wheel. I'm thinking it's the power...
Why does power steering get harder at lower speeds
if the belt is nice and tight and is spinning around the pulley and fluids are full, then your steering pump is going bad
2answers
92 lexus ls400 lets out a puff of smoke when u start it up but doesn't after start up
check power steering levels i have the same year Gen I-III have a power steering defect PS fluid pumps into system then out tail pipe, white smoke.Lexus fixed this in later models.. check lexls.com the solution is there.
1helpful
2answers
1991 lexus ls400 power steeing slowly got hard to
As mentioned check ps fluid. If it wines when turning and still no power then the pump is internally bad.. If the fluid is dissapearing fast then its a hose or most likely a leaking rack& pinion assembly..
2helpful
2answers
Lexus LS400 loss of power and excessive fuel consumption and rough or low idle speed. HELP!!
check the computer known for going bad. auto computer exchange in Davie fL can fix it
2answers
Telescopic Steering wheel won't move down or up
Yes it would be perfectly ok to disegauge the auto switch to keep it from moving again. It needs a tilt motor replaced . not a easy job.
1helpful
2answers
Top Lexus Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Are you a Lexus Expert? Answer questions, earn points and help others
