The trippers on the dial are set but the free spinning dial won't trip the on or off settings.
Apparently no one understood the question: the dial rotates freely, doesn't activate the switches. What's the fix?
120 Volt Clock motor might be bad?
Tighten the nut that holds the dial?
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: My intermatic timer won't trip back on
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: I have a Tork timer model number 1101 24 hr time
Tork 1101 is a 120V mechanical dial-type timer
Tork 1100 series
To set timer, you lift and rotate dial. Line up current time with the word Time located to lower right of dial.
Next, place trippers on dial. Dark trippers are OFF and light-colored trippers are ON
Tork 1101 is 120V timer.
120V Black Hot wire from circuit breaker connects to Pole L
There is a brass bridge that connects Pole L and Pole 1 >> if this is missing, put a jumper wire that connects both Poles
120V White Neural wire from circuit breaker connects to Pole X
White wire going to Load (lights, fan, motor) connects to Pole X
Black wire going to Load connects to Pole 2
Up-vote if this information was helpful. Thanks for the feedback.
SOURCE: i need the owners manul
You can get the manual on the link beow.
http://www.hardwareinnovations.com/pdf/SA_220_IB60642_73.pdf
Good Luck
SOURCE: I have a Tork 1101.
Tork 1101 is 24-hour 120Volt mechanical dial timer
ON-OFF trippers are placed on outer edge of dial to set on-off times.
These tripper click on-off lever back and forth.
Trippers wear out since they are intentionally made of softer metal than on-off lever
Frontier lighting carries P47 tork 1101 replacement trippers
http://www.frontierlighting.com/product.jsp?part=3495&process=search&show=&
Make sure these trippers match yours before ordering
SOURCE: I have a 15 yr old tork 1101 pool timer. I
1) Tork P47 tripper is correct tripper for 1101 timer.
Trippers are brass-colored and black-colored.
If they do not fit timer dial you might need new timer.
http://www.frontierlighting.com/find.jsp?a=1&ID=,Photo.Cells...Time.Controls,Replacement.Trippers
2) Buy new 120Volt indoor/non-weathertight Tork T1011
To identify timer for sure:
3) Google search Tork 1101 shows timer cost $83
4) Intermatic cross reference shows replacement is T-101 indoor/non-weathertight
Amaxon sells T101 for 43$:
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
5) Raintight/outdoor: Aplus and Lowes sell raintight outdoor T-101R for $71
http://www.lowes.com/pd_29405-251-T101RD89_0_
http://www.aplussupply.com/intermatic/timer.htm
6) Cross over wiring.
Tork terminal X is T101 terminal A
Tork terminal 1&L are T101 terminal 1
Tork terminal 2 is T101 terminal 2
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
