I get the video adapter error when trying to install the software for Digital Arts studio Fisher Price. I have called the support desk 3 times and emailed once to no avail very very unhelpful to say the least. All my drivers are up to date my system meets the requirements and still it wont work. Help any ideas as to what driver it is looking for and how i can install it and make it compatible. I have had this thing for almost 2 weeks and my 4 yr old is very annoyed that it wont work.
Comments:
Jul 05, 2009
- Thanks for the link I have previously been directed to this link and all my updates have been undertaken and I dont have any of the other issues so this doesn't help me. If I knew what the video adapter was that it was referring to that may help but they are up to date anyway.
Jul 05, 2009
- I have it just says that the video adapter is not installed properly or not compatible.
I have a code 31 error on AMD 8151-Transport AGP 3.0 Graphics Tunnel, I have no clue if this is related or not i have run a code 31 error fix but no go
towards the bottom, I hope this helps. If not, let us know.
Comments:
Jul 05, 2009
- do you have the exact video error or code?
Jul 09, 2009
- Do you have the specs of the computer? The only thing I can think of is to give us as much information as possible. This is one of those situations where the smallest detail could give us the answer.
Also, a restore is always a good way to cut the possible reasons. This removes the possibility of a conflicting software or driver. Just make sure you install all the correct drivers, etc.
Looking for a replacement for a Logitech wingman force 3D Joystick used mainly with Microsoft flight...
(More)
Looking for a replacement for a Logitech wingman force 3D Joystick used mainly with Microsoft flight simultor.
Tenho um Lcd Asus VW193D, desde o inicio do ano de 2009, sem qualquer problema, e agora,...
(More)
Tenho um Lcd Asus VW193D, desde o inicio do ano de 2009, sem qualquer problema, e agora, após ter formatado, estou com um problema - NÃO LIGA ao Desktop.
Será que está mal configurado? o Windows é o Xp, e foi configurado com o Plug & Plug? Será que a ficha avariou? Será da Placa? Memória?
Por favor não sei o que fazer.
Já experimentei com outro monitor e o problema mantèm-se, ligou no início e após alguns segundos, desliga (c/luz amarela - parece suspenso) e já não liga.
Agradecida antecipadamente
Filomena Moraes
I have a HP Media Center M7000 desktop. I power it on and after about 8 seconds it powers off. I...
(More)
I have a HP Media Center M7000 desktop. I power it on and after about 8 seconds it powers off. I removed all cards, disconnected the CPU fan, removed memory simms to no avail. I disconnected the hard drive and it made no difference. I removed the P7 (12 volt) connector and it stays up (not doing much of course) and I measured the voltage on the P7 and it's 11.83 on both so that's within spec. Any ideas what to do next other than replace the motherboard? What could be shorting out the motherboard so the whole thing powers down?
GA-8TRC410MNF-RH Hello, I have given this motherboard and I know the position of the panel...
(More)
GA-8TRC410MNF-RH Hello, I have given this motherboard and I know the position of the panel connectors (power led, hdd led, reset etc..) And the colors and polarity. Greetings.
