Your unit should have voice. Here is the manual in case you don't have it. If you need further help, please ask. I am unclear if you think your GPS is faulty or you just need help with set up.
Well according to Megellan, it does have turn by turn voice prompt.
http://www.magellangps.com/products/prod...
Page 5 in the manual explains the volume control. Tap the speaker icon,
tap inside the volume adjust bar to adjust volume, tap save. Please try
this. If it doesn't work still, your unit is faulty. Unfortunately I
cant see it in person to check it out. There is no other solution. Nobody said you were stupid and I am only trying to help with the only possible solution. It happens that sometimes little things get overlooked.
According to the company, it does have that option. If yours doesn't and you don't think it's faulty then problem solved. You particular unit then does not have that option.
Ok, my mistake, its the 4040 that names the streets. The 4000 just announces the turns. I apologize for my overlook. The 4040 is the next model up and has a few more features that the 4000 doesnt.
listen carefully voice works it does not have the option like the 700 to annouce street names with every turn,this option was in the voice menu in the 700 male,female and annouce street names,it does not have it on here.the manual do not help,i am not that stupid,i already have the manual.try again ok
soo where is your answer now ,mr night71,respond now
listen carefully voice works it does not have the option like the 700 to annouce street names with every turn,this option was in the voice menu in the 700 male,female and annouce street names,it does not have it on here.the manual do not help ok.
also my unit is no faulty. it is you that do not understand
if it does ,i chk the whole unit.then they should have a firware update to fix it, if does not have. do to their screw up.it does say right turn .o5 miles then ding ding etc etc.the 700 had that you can have that option to annouce the street names it self,right turn on irving st,left turn on lincoln blvd,etc etc.
