SOURCE: water leaking from back of m/c
You may have accidentally disconnected the pipe which takes water from pump to bottle.
Please post back if any assistance needed to access pump.
Thankyou for using Fixya.
SOURCE: cannot get into back of tumble dryer to fit new belt
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
SOURCE: what is the best way to put a new drum belt onto
Here is a link to a video that will help you with this repair.
http://www.youtube.com/watch?v=BiYFDAZVFaw&feature=channel
SOURCE: my white knight tumble dryer
Your belt probably broke or fell off the motor . The humming noise is the motor running without a belt on it
