I have a compaq HP 6715s laptop, recently I noticed it was not charging any more, so I tried Using another charger, tried my charger on another charger, and it was charging that other laptop...so i felt it was from the port on the laptop...when I used multimeter to test the input volt from the port I discovered it was passing through...I dont really know if some other components are bad or what..maybe U could offer assistance that will be highly appreciated.thank Ukeje Evrest
If you can determine that it is not the battery just going bad, then most likely it is a problem with the motherboard. I actually have this same problem, and have not been able to find a quick fix.
HP has a battery tester tool. If you are able to use this, then you are one step ahead of where my HP laptop is. I tried running this and it insisted that I did not have a battery installed, or that it was dead. If you have this same problem, then it looks like it might be time for a new motherboard.
In anycase, it might also be worth the time to try draining the battery completely and attempting to charge it back up. According to a few other sources, the laptop can sometimes get confused and think that a full battery is calibrated to be a low battery.
Was this helpful?
Yes
No
Popular Solutions for HP Compaq nx7300 PC Notebook
I removed the screen and exposed the power button circuit board. I checked for voltage and only...
(More)
I removed the screen and exposed the power button circuit board. I checked for voltage and only found 19vDC on the main pin. Looks like either this pin has a bad solder connection, or a resistor (or fuse type part) is burned out. Where do I get a schematic for the power supply circuit (MX6448)
have dell 1555 with Vista Home Premium. Have MSN as homepage. Now get broken link to home page and...
(More)
have dell 1555 with Vista Home Premium. Have MSN as homepage. Now get broken link to home page and cannot get to msn.com. Gives me error related to dell v14 msn. any known problems or solutions?
my compaq nx7300 doesn't recognize Alesis io 14 soundcard partialy, i.e. it is recognized- and...
(More)
my compaq nx7300 doesn't recognize Alesis io 14 soundcard partialy, i.e. it is recognized- and working ok- by Cubase or other stand-alone VST's, but not by the WinMedia player.What can i do? Thank you in advance, Nik
hello,my hp nx7300 is running very slowly;it takes more than an hour to install os.Would you please...
(More)
hello,my hp nx7300 is running very slowly;it takes more than an hour to install os.Would you please tell me somethiong about it thank you!
