Question about Sony PlayStation Portable (PSP) Console
Surround sound on sony playstation 3
Video picture with hdmi cable no 5.1 surround
  • Anonymous May 16, 2008
    i can not get any surround sound with my ps3 how can i solve this
  • 31 Answers
Sounds like you need digital optical audio cable. It will work.. as long as your home theater has it. http://www.madcatz.com/ and look for ps3 then cables.. and you should see the digital optical cable.
Posted on Nov 13, 2007
Sony Playstation 3. There is no picture, only sound through HDMI cable connection to TV from my playstation 3.
Does your HDMI cable was placed properly through the television and in the PS3 unit ? , If Yes then does you HDMI cable have defects ? If No then whats your PS3 ? Slim or Super slim or Fat ?
Oct 26, 2013 | Video Game Consoles & Games
I connected a sony playstation 3 and there is no sound while playing games. The video works and I can play the game, but there is no sound. I returned the playstation 3 thinking it was the console but the...
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
Adjust the audio output on your playstation and the television depending upon how you're connecting it to the television for picture and sound.
For an hdmi cable between the television and the PS3 only then adjust the audio ouput to hdmi on the PS3.
You do not need to connect anything else between the television and the PS3 besides an hdmi cable.
If you are using the colored plug type component or composite cables then it is av.
If you are connecting with a fiber optic cable to a surround sound system then it is set to optical.
Depending on what television you are using you would also have to change the Playstation to 48khz/96khz
Jan 09, 2011 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Want to use surround sound and use dhmi cords for picture and surround sound
You will need 2 hdmi cables the ps3 a tv with an hdmi port and a audio receiver with hdmi in and out.
1:>First connect the ps3 to the tv with the A/V cables.
2:>Turn the system on and the tv on, get to the ps3 dashboard.
3:>Under the settings tab select (display settings)
4:>Select (video output settings)
5:>Do not disconnect the A/V.
6:>Connect the hdmi cable to the ps3 and tv.
7:>Then select hdmi and select change, this gives you 30 seconds to switch the tv over to the hdmi channel. Once done and you get a signal select (yes).
8:>Disconnect the A/V cable.
9:>Select what inut your tv will support 720i, 720p, 1080i, 1080p. You can select more than one and even all if it is supported by your tv.
10:>Then select hdmi for your audio output, but since your ps3 is connected to the tv only select linear PCM 2channel. Check for sound on the tv's speakers. If check is good then proceed.
11:>Power down the tv and ps3, disconnect the hdmi cable.
12:>Connect the hdmi cable from the ps3 to the input of the audio receiver and the hdmi from the tv to the output on the receiver.
13:>Turn the ps3 on, the receiver on and the tv on. Make sure the receiver is on the right channel. If it is you will see the ps3 come on the tv, and have sound on the main speakers of the receiver and tv.
14:>At this step you should be able to see and here the ps3's dashboard. Now to setup surround.
15:>Scroll to the settings tab and select (sound settings).
16:>Select (audio output settings)
17:>Select (hdmi)
18:>Select (automatic) this will select the basic surround settings that all receivers have.
19:>Hit enter and exit.
20:>From here test the surround with a game or movie.
If for any reason you should need to restart the process, simply plug the A/V cable back in and do a video reset. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} 1:>Turn the system to off/standby, where only the red light is on.
2:>Then hold your finger on the front power button, it will turn on beep twice then shut back off, release finger.
3:>Then turn back on normally.
Good luck.
Dec 28, 2009 | Sony Playstation 3 (PS3) Console
No surround sound when playing PS3 through HTDDWG700 via 2 HDMI
The HTDDWG700 does not transfer the audio through the HDMI cable that the vision goes through. To solve the problem i got an optical cable and connected the PS3 to the receiver with the optical and put the HDMI cable from the PS3 to the tv.
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
No surround sound, when playing blue ray films using ps3
Im guessing you are using a HDMI cable,
HDMI cables struggle to carry audio...
you will need a componet cable, this is basicly the same quality, and all you do is plug the audio cable part into the surround sound system and done.
Hope this helps
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
No sound with ps3 hdmi hook up
Hey there, The same kinda thin happend with my surround sound have you checked under the audio options that the right cable is selected ?
Feb 08, 2009 | Sony Playstation 3 (PS3) Console
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Ps3 Surround sound
ttttttttttttttttttttttttttttttt
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
What do i need to got sound out of my hdtv?im using a hdmi to dvi cable.
if you have no optional external speaker on the ps3 you may have an earphone socket which can be connected to your tv's pc sound input via a 3.5mm or 6.5mm jack plugs.
Aug 13, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation Portable (PSP) Console Logo
65 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
