Error message F15 keeps coming up and the machine stops is this repairable?
Hi there, it's Jack at Dyson.
I can confirm that an F15 fault means 'Gearchange failure (too slow)'.
Unfortunately, since December 2012 we have been unable to offer servicing or support for CR01 or CR02 washing machines. In October 2012 we proactively contacted all Dyson washing machine owners we'd interacted with within the last 4 years to make them aware of this.
I'm sorry that I'm not able to help further in this particular instance, but if you'd like to discuss this with our experts you're welcome to call us on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
SOURCE: Fault F15
the gearbox actuator is seized....calll dyson and they will fix iy......free!!!!!!!
SOURCE: Hotpoint WD420 Dryer heater relay
You must check for overload try to messure the amount of clothing you adding to the machine, and try to restart by unploging the aparat from the wall outlet, wireing diagram are located usualy on the back of the aparat.
SOURCE: we cannot open the filter for the WT741
F15 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit to check wire harness connections to the motor, MCU, and Central Control Unit (CCU).
Check the drive belt and reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor and check the drive motor for powered rotations.
Replace failed component.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: F 19 error on Whirlpool AWM 8085
SOURCE: Hi. Anyone who knows what the fault F15 means on
