Question about Frigidaire GLRS264ZA Side by Side Refrigerator
Frigidaire GLRS264ZA side by side diode
I replaced the diode in the wiring harness because I was having a problem with water to the door and icemaker at the same time. Since I replaced it myself, could I have damaged it unknowingly? Because I am still experiencing the same problem.
  • 236 Answers
Re: Frigidaire GLRS264ZA side by side diode
As long as you replace it with the same capacity of diode and there is really a diode in the wiring harness and you did not reverse the connection of the diode, then your are safe.
Posted on Jan 12, 2008
0 characters
3 Points
New icemaker with new water valve and still won't make ice
check the setting on the control panel, it may be just turned OFF
Jul 13, 2014 | Frigidaire GLRS264ZA Side by Side...
Frigidaire glrs264za ice in freezer
The ice-maker supply line enters the back of the freezer near the top. There is a rubber piece that fills the ice tray, attached from the outside. If that is cracked you will have a leak. There is also a water line that runs through the refrigerator to the reservoir that supplies chilled water at the door. All of these lines should be checked for leaks that can drip into the freezer compartment.
Apr 01, 2014 | Frigidaire GLRS264ZA Side by Side...
Water comes out of water dispenser on outside of frig and no one is touching it. seems to turn on by itself
Hello, welcome to FixYa.
Based on your post I understand you have a problem with a refrigerator, model:FSR26H5AS correct ? Does it only shoot water out when the icemaker fills with water ?
If that's the scenario and If it is indeed a Frigidaire side by side, this is a problem associated with a faulty diode which controls voltages to the inlet valves.
Here's what you can do, if you have an ohm meter and measure accross the diode and get little to no resistance the diode is shorted. The diode may not be obvious as it is usually along the back wall (back of outside cabinet) and wrapped in an insulator.
The other way to check is through a voltage test. Measure voltage during an icemaker fill or a water fill to a glass, if there is voltage at all the valves at the same time, you have a shorted diode.
If so this is the kit required to remedy the problem, #5303918287. It simply can be "spliced" into the existing wires and includes the primary component, the diode.
I'll watch and look forward for your reply and we can go forward from here if you need any further assistance.
Thank you for visiting FixYa for your inquiry.
Macmarkus :)
Aug 25, 2011 | Frigidaire FRS26H5AS Side by Side...
My 7-button Frigidaire Gallery ice/water module is not lighting up and not functioning. No ice or water is being dispensed. Wiring harnesses seem to be all intact.
If freezer door switch is not working, dispenser won't work. Does the freezer light go off & on when door is opened & closed? If you have a voltmeter, check that water valve is getting 120 volts when dispenser is pushed in. If no voltage, I would suspect the micro-switch that you hear clicking when you push in with a glass. Even though it clicks, the contacts could still be bad in it. However other than that loose/off wire, ribbon cable for front buttons off/loose, bad board, child lock are something that can make the dispenser dead.
Please check the bellow link if it helps:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Mar 29, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Is the icemaker turned on? water supply turned on, Did you replace the water valve as well? and is the temperature of the freezer reaching 0 degrees F?
Aug 29, 2010 | Frigidaire GLRS264ZA Side by Side...
Not getting water to my icemaker.. water is coming out of the water side(drinking)water is coming into refrigerator from mainwater supply. replaced water triple cylinode valve already, but not getting...
frigidaire has put a diode in the harness @ the water valve sounds like diode is bad . hard to find @supply houses may have to order complete wire harness haundi24
Oct 12, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice Maker gets flooded with water when using the water dispenser
There is a diode in the wire harness near the valve. It has failed allowing power to go to both valves at once.
Unplug the wire from the valve to the icemaker and unhook the icemaker. This should stop it until you can get the part.
Jul 27, 2009 | Frigidaire FRS26R4A Side by Side...
FRS26ZSH Water Dispensor Not Working
I have a GE 2005 Side by Side Refrigerator. Model GSS25JERF, Serial # FH242429. I get all kinds of Ice but no water. I replaced the water valve (p/n WR57X10050) and the Dispenser Display, 4 button ( p/n WR55x10443) Still no water dispensing from the water valve. What next ?????
Feb 28, 2009 | Frigidaire GLRS264ZA Side by Side...
Water coming out door and into icemaker
welcometo the world of FRIGIDAIRE!! only company i know using that DIODE within the harness, im unable to lok up the part number for the DIODE kit, there are 2 of them, i would call the manufacture and ask them to supply you with number... just seems a ltiile wierd that ice maker fill troughdoor andyour water fill the ice machine, i see that you tried switching wires and lines still thesame result, please excuse the silly question but did you try to just switch the wires to the dual valve??? not worrying abouth the lines. just askin.
Mar 21, 2008 | Refrigerators
When icemaker is filling water comes out door dispenser
I need the entire model # from the sticker inside the fridge section. My guess is this is the model that has a diode in the wiring harness that directs power to the valves and has gone bad letting power go to both valves. I would look and see if you also have water going into the icemaker when you press for water out of the dispenser. If there is no diode then the water valve is bad. I need the model # so I can look at a wiring diagram. You can look at the wiring to the water valve and see if it has a diode. It is black block and has two wires in one end and one out the other. If so the diode only can be bought and spliced in. Let me know so I can help.
Nov 02, 2007 | Frigidaire GLRS264ZA Side by Side...
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
197 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
