Hello . hope this helps . not easy but id doable , plan this when u have some time. how hard to do it yourself 1-10 id say 8
1st unplug the dryer .
remove 2 screws located in the rear top of the dryer , those screws are holding the top panel in place.
once you have removed those screws go back around to the frt of the dryer and with your hands on top of the panel push the top panel back and top panel should lift back and out.
next remove 2-3 screws holding the faceplate (display panel) to the frame , from the inside and unclip the wiring harness and set to the side. next remove 3-4 screws holding front panel to the cabinet of the dryer then reove front panel and set to the side now you can see the heating element enclose in a housing. remove a screw holding the housing and slide housing to you. disconnect the 2 connectors going to heating element. some revisions heaters slides out , some models you must remove a few screws holding element in place. Samsung does sell the heater assy witch comes all together for a few more dollars but less labor. re assemble
Check
your heating element..
A
bad heating element causes many problems in dishwashers...
Dishwasher
Problems The Heating
Element not Working
How
to Replace the Dishwasher Heating Element
Dishwasher
Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give
it a go and see how simple it was. thanks Ronnie " -
ronnieshomes
