I had three calendars, birthday, work, home. While editing birthday cslendar the other two have disappeared
The likely cause of this problem is that you're synchronizing your iPhone Calendar with iCloud or another online calendar service and your iPhone is set to sync only recent events. This option can be found underMail, Contacts, Calendars in your iPhone Settings app. The default setting is one month, however you can tap on this option and choose from either two weeks, one month, three months or six months or simply choose All Events to sync everything in your calendar.
New events created in the iPhone Calendar outside of this time frame are still saved and synchronized to your online calendar (e.g. iCloud), but once the online calendar has been updated, they are removed from the local iPhone Calendar; hence these events appear to vanish shortly after you've created them. Items you have created on these older dates will actually have been saved in the cloud and you would likely be able to see them on a desktop computer; iCal for Mac, for example, automatically synchronizes all events from iCloud to your desktop calendar, regardless of the setting on your iPhone. Further, if you're using iCloud you can log onto iCloud.com from any web browser and you should see these events in your Calendar there as well. In fact, if you adjust the sync setting above to a longer time frame-or All Events-all of these "lost" events should automatically be synced back down from the cloud and reappear; you'll likely even see all of the instances of events that you tried to create multiple times.
Ultimately, unless you have a very large calendar going back several years, it's probably best to just set your sync events preference to All Events, which will ensure that your entire calendar is available on your device and avoid any future confusion with vanishing events.
SOURCE: Calendar Colors
The iPhone does not put the calender colors in the right order.
Thank You,
Apple Care Service And Support
Nick M
SOURCE: Push Erased Calendars / Calendar colors
Well you have to set up Mobileme for the iPhone 3G.
Thank You,
SOURCE: Can't sync outlook 2003 calendars with iPhone 3g
Synchronization of iPhone 3G with your Outlook 2003 will depend on the type of account that you would like to create. It will depend also on the Web mail that you are going to download.
Example:
1. The e-mail that you would like to download to your iPhone is your Gmail account. You have to enable POP in your Gmail sesttings.
2. On your iPhone > go to Home screen > tap settings...
3. Go to Mail > Add Account > Other > Continue...
4. For the host name: pop.gmail.com
5. For the username: type your complete e-mail address
6. For the Outgoing mail SMTP Host name: type smtp.gmail.com
7. Tap Save..
8. To verify your Advance configuration: Go to settings > click the account that you havve created > Advance
Incoming server port:
-You may use 110 or 993
-Type your password
Outgoing settings:
- You may use 25, 2525, 587 or 465
- Type your password again.
You're done.
NOTE: I just use Gmail as an example. Your incoming mail server will depend on your Web mail settings.. You may contact your e-mail administrator and ask for the Incoming mail server, Outgoing mail SMTP, ask if your account requires encryption or not.
