Question about JVC AV-56WP30 56" Rear Projection Television
Convergence how would you rate this tv?when i bought this 3 years i bragged as if i spent $5000.in feb i had to replace my circuit board at a cost of $700. well the famous reg,green,blue ghost showed up and then the screen when black.so at another $700 i might as well upgrade to a new tv right?at least it looks pretty in the corner of my den still!
    President:
  • 4,402 Answers
Why are you spending so much! you could get the board repaired for a fraction of that ptscorp.com
or do this yourself.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Posted on Jan 31, 2008
53uwx10ba.....seeing double/triple, colors primarily red white blue...can we fix this ourselves? and does the front of the tv come off?
Yes,but the front that not what u wanted to be open.The back of the tv that what u wanted to be open.That where the tv convergence board is,that the board require reparing.Yes,if U have all the tools and can do basic soldering works too like take out desoldering ICS take it out of a circuit board and resoldering ICS on put in onto a circuit board and also desoldering/resodering like take out small components parts and replace with new small components parts onto a circuit board?Yes?The tv convergence board must require replaces like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.Tries websites like Tvrpairworld.com,Tvrepairkits.com to buy a whole complete convegence kit belong to ur tv make and model the kit also will have a dvd disc of tutoring job too.Or tries tvs shops will cost u like $300-350 for parts and labors.
Sep 03, 2011 | Hitachi 53UWX10B 53" Rear Projection...
It appears that I'm seeing 3 images red ...yellow and blue, it's like they're not in sync with each other, it was working fine and then poof!what do I need to do to fix/ I don't know the year or model #,...
Most common problems belong to the DLP tvs design.The problems u having are commonly call the convergence problems.The tv have it R,G,B colors lines mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all of it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.U have tools like a soldering iron,desoldering pump or desoldering braids,solders and a know how to do basic soldering?Yes,than u can tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.Or the shop,will cost u like $300-350 for parts and labors.
Nov 04, 2010 | Zenith Televison & Video
Tv all of a sudden starting showing everything in 3D picture outlined in green. The model # is -53x54j the serial # is LY43060344. The tv was manufactured on November 2004 and that is also the month and...
What you have is a convergence module failure. This involoves two boards known as the Sustain Boards. However the power board may also be involved.
Manufacturer recommends that all 3 boards are replaced as they compliment each other. It is not a DIY ( board swapping is not like PC these boards have to be tuned to each other and require special tools and circuit Diagram to check voltage points
I think you are lucky to have had it this long without failure. Estiametd cost for parts is $300 + labour. Alomost not worth fisxing, as standard televisions can be bought cheaply from second hand dealers quite cheaply and have a 30 nday warranty
Please rate my help++++Thanks for using FIXYA
Jun 09, 2010 | Televison & Video
Red light blinks no picture or sound
took the board to friend who works on TV's.he tested the board and replaced the 2 black IC's #STK 392-040 .I re-installed the board and TV so far is working fine. hope this helps !
Jun 18, 2009 | Akai PT4298HD Rear Projection Television
Blue and Yellow lines showing up on the screen.
STKs cost no more then 19.00 each www.electronix.com they have them replace both ICs use 392-180s better ics 100 percent holdup rate. they are big black ICs retail on ics 55.00 each
Nov 30, 2008 | Philips 60PP9202 60" Rear Projection...
CONVERGENCE GRID IS OFF ON MY RCA P61929
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it. If that doesn't work the nodules need replacing.
Jan 03, 2008 | RCA P61927 61" Rear Projection Television
I need help please...
You will need to replace the convergence output IC's and check the resistors in that circuit.
Apr 12, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Toshiba 51H84
convergence IC's need to be replaced
Dec 12, 2006 | Toshiba 51H84 51" Rear Projection...
JVC AV-56WP30 56" Rear Projection Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
