John Deere Replacement Hydrostatic Transmission Lt150, Lt160, Lt170, Lt180 Logo
A
Anonymous Posted on Oct 09, 2014
Travel pedals do not engage.
The motor runs fine. When I depress the forward travel pedal or the reverse travel pedal, the mower does not move. What do I need to do?
Dave Bisset
Level 1:
Scholar:
New Friend:
  • Contributor 71 Answers
  • Posted on Oct 10, 2014
Dave Bisset
Contributor
Level 1:
Scholar:
New Friend:
Answers
71
Questions
Helped
29969
Points
78
Things to check out. 1. That there is oil in the drive unit. Is there a reservoir on top and can you find a dipstick? A reservoir should be half full at least. 2. Is the disengage lever or rod pushed in? Look to the rear of the machine frame and low down. This disengages a valve to enable the machine to be moved without the motor running. If in the open position the drive will not work. 3. Check that the belt is driving the pulley on the top of the transmission. This normally has a tensioner which automatically takes up the slack. A worn belt can slip or jump off the pulleys. Look at the motor drive pulley to ensure that the belt is still on it. This is NOT the bottom one which drives the deck and has an electric clutch.
5 Related Answers
Anonymous
  • 146 Answers
  • Posted on Jun 09, 2010
SOURCE: JD 3320 tractor with error code 57
From what I can find, that is a 'timeout' error indicating the expected signals from the hydrostatic transmission are not being received. That would suggest that some of the wiring is still not repaired. Could it be the nice doggie pulled out a connector partially and you didn't notice? Make sure all connectors are firmly seated.
Some have seen this error code occur for the simple reason that the battery voltage was borderline low -- those computers are sensitive. So before you take it to the dealer, put the battery on a charger overnight to see if that resolves it.
Hope this helps. If so, please rate my solutions, thanks and good luck!
Anonymous
  • 1627 Answers
  • Posted on Nov 10, 2009
SOURCE: Scott's L2548 ridng mower, transmission will not
You either have the handle that puts the machine in nuetral in the pulled out position or your drive belt is broke or slipping .
Anonymous
  • 11 Answers
  • Posted on May 05, 2010
SOURCE: 320 john deere mower starts sputtering and pulling
How old is the battery, and is it in good condition?
Anonymous
  • 72 Answers
  • Posted on Nov 17, 2010
SOURCE: my 4210 4x4 with hydrostatic
Hi, the engine will power the hydrostatic drive via a drive belt. See that this belt is in place or if it is worn out and loose. By replacing this belt you should get your machine running again. Hope this helps
philwalker78
Phil Walker
  • 610 Answers
  • Posted on Apr 11, 2011
SOURCE: I have a John Deere LT 133 lawn mower, when I
There will be a faulty safety switch somewhere. Most likely the one on the seat. Regards Phil
John Deere X320. If at any point while I'm mowing I back up mower will not re-engage.
The wiring diagram shows the reverse switch is normally closed until activated. This would mean forward travel requires switch closed else PTO disengages... same as your experience.
From your description of progressive failure I suspect the switch has failed or has come loose and moved from it's normal position.
Go to the JD website below and search "reverse switch". A parts diagram should display. Look for item 15, part number LVA13307
https://partscatalog.deere.com/jdrc/navigation/equipment/61166
The reverse pedal or linkage must somehow activate the switch.
There could be a problem with the PTO switch or safety interlock module or electrical interconnections so if the reverse switch checks out, further troubleshooting will be necessary. Start at the reverse switch and work your way to the PTO switch then the interlockmodule.
1helpful
Cannot engage parking brake on John Deere L108 mower. Clutch and foot brake work fine. Cannot lift orange lever to set. What can I do? Thanks
If new to the unit...
To set parking brake, you FULLY depress and hold the brake/clutch pedal, engage and hold park brake lock, release brake/clutch pedal. You may need to adjust seat forward.
Else...
If the brake lock won't move when brake/clutch is fully depressed, check for obstruction in brake lock linkage.
Husqvarna mower forward/reverse pedal is stuck in the forward position. Engine runs but transmission not engaging. Cause-probably pushing pedal forward when cruise was set. How can I get it unstuck?
My forward pedal flopped forward and my mower no longer moves forward, only in reverse. Hard to find a diagram to locate the problem. Can anyone help?
Why isn't something engaging when accelerator pressed?
It would help to know more information about the mower in question. Walk behind push mower? walk behind self-propelled mower/ Riding lawn mower? Lawn tractor? Or goat...just kidding...lol. The engine horse -power or cc's and make of the mower and engine. Anything happen before the problem or was it straight out of storage. Does the gas pedal feel normal? Could you be talking about the forward/ reverse pedal? These types don't engage by depressing them, they engage by releasing the pedal.
I'm going to guess you have a riding lawn mower or lawn tractor. The pedal for those types of mowers controls the transaxle ( rear wheels, transmission and differential basically). If the pedal move properly and it was working ok when it was stored, then check to see if you can push it with little effort. On most transaxles there is a disconnect rod to disengage the transaxle for towing the mower without damaging it. Pulled out for disengaged and in for engage. If that all checks out it could be very low on transmission fluid or the drive belt might be off or broken depending on which type you have. If it is low on fluid, you have a leak. Hope this helps.
Mar 11, 2016 • Garden
2answers
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Toro 425 Riding Mower Keeps moving once pedal is released. It has a forward and reverse lever and then a pedal for speed. The brake pedal does not seem to do anything to stop mower.
I have had this exact same problem, doesn't happen everytime, but when it does it's scary. I depress the gas pedal, the mower moves forward, it has a hydrostatic transmission so when I release the gas pedal it is supposed to stop, but doesn't. I slam on the brakes but they have no effect at all, have to turn it off with the key to avoid crashing. The thing is the brakes work when this is not happening.
Aug 06, 2013 • Garden
Cadet LT 2042 worked fine changed hydro filter by lifting front with hoist to vertical. Lowered and topped off fluid. Now wont go forward or reverse. Makes no noise when pedal is engaged to move either...
You will have air in the system and will need purged. To do that you jack up the wheels to where they will turn freely then disengage the hydro and at an idle alternate forward and reverse for a for about 4 or 5 minutes. Recheck the fluid level and top off. Now engage the hydro and do the same forward and reverse for 3 or 4 minutes. You should have axle movement at this point. Hope this will help.
1helpful
When I depress the forward drive pedal I move very slowly weather the deck is engaged or not. It is also very slow and sometimes stops in reverse. I usually have to use my foot and pull back on the...
You didn't specify a brand or type but it sounds like a hydrostatic drive model and if so, it is 1 of 4 likely things
Drive belt from engine to transaxle slipping badly (replace the belt)
FWD-REV pedal linkage faulty
Transaxle is broken or has fluid issues (not user fixable)
by-pass rod (neutral lever/rod) is pulled out a bit. (push it in fully!)
Jul 11, 2010 • Garden
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
