A GUY JUST CAME OUT AND SAID THE COMPRESSOR WA BAD, WHICH I THOUGHT THE SAME CAUSE IT IS MAKING A RATTLING NOISE. BUT, HE SAID I MIGHT AS WELL REPLACE THE WHOLE UNIT RATHER THAN JUST THE COMPRESSOR CAUSE THERE IS ONLY ABOUT A $400-600 DIFFERENCE
You have 10 seer 4 ton unit. A compressor install in my company (4 ton) is about 1400 dollars. Remember when you change compressor you only get a 1 year warranty. A new unit can have as much as 10 year compressor warranty. Amana has a 10 year parts and labor with their unit. The new unit will be 13 seer and you may have to install a TXV inside. You might think about changing the whole system with the new 410A system. Either way a new condensing unit is needed. I have not had anyone just change a compressor in an older unit. Just not cost effective. Get several estimates before you make up your mind. Rus
I have a 10 inch Sear outdoor RUUD Thermopump. The coils are collecting frost, I hear it making some...
(More)
I have a 10 inch Sear outdoor RUUD Thermopump. The coils are collecting frost, I hear it making some knocking noise for just a short period of time until it stops and starts running normally. It stop before I could get out to realize the source of the noise. Any suggestions until I get a service maintenance on this unit? The house is being heated.
ac sensor can not be used, I've tried to replace the sensor, could be just 10 minutes and then die...
(More)
ac sensor can not be used, I've tried to replace the sensor, could be just 10 minutes and then die again what should I do?
