Question about Apple Cinema 20" LCD Monitor
Cable chewed through
Want to replace main cable.  need part and disassembly instructions
0 characters
1 Points
Where can i get a new hp pavilion f1523 keyboard looked all over the internet
Any USB keyboard will work on the computer. You can purchase a very cheap one (basic) or if you need require it and very pricey one (lots of do dads). The point is you do not need to replace the keyboard with an HP keyboard.
May 30, 2012 | Computer Monitors
Instructions on how to disassemble and fix a Viewsonic VX2235WM
Here is a link to a repair guide that shows how to dis-assembly the unit and that what to look for any replace on the power supply board to repair most problems on the VX2235wm monitors. The repair guide has pictures and videos showing the procedures.
I hope this helps, if so please rate my solution.
May 19, 2010 | ViewSonic VX2235WM Monitor
Dog chewed cord in half. Not power cord - feed cord. I have it apart, where can I get a new cord. Its a Dell flat screen monitor- Model :E151FPb
You need a DB15 Video cable, they are available at say... Radio Shack, or the like, any good PC store should have them.
Feb 21, 2010 | Gateway FPD2275W LCD Monitor
Hp 1703 Video for 1second then Black Please Help if you replace the main boards ( Power & Video Or just the Power Board) will this fix the display issue. thanks
You may want to check your power and connection cables are not showing bare wire, which is the metal hanging out of the rubber insulation cord. So just check for that and if not that I would call HP.
Jan 30, 2009 | HP Pavilion F1703 17" LCD Monitor
My wifes dog chewed the cable that is hard wired into the lcd .
If it's the screw on type on both ends (I'm assuming it's the video cable), you can unscrew both ends and get another VGA cable (under 10 dollars each).
If not, you might want to consider keeping the dog away from cables, it was lucky not to chew on charged wires.
Dec 14, 2008 | NEC MultiSync LCD1512 Monitor
Need help finding replacement monitor cable
what color are the ends of the cables, blue you need a vga cable, white a DVI cable- there are two types of dvi cables look at the connector if it has a plus sign in it you need a dual link otherwise a single.
Oct 26, 2007 | ViewSonic G790 19" CRT Monitor
Apple Cinema 20" LCD Monitor Logo
27 people viewed this question
Top Apple Computer Monitors Experts
Level 1 Expert
david willimes
david willimes
Are you an Apple Computer Monitor Expert? Answer questions, earn points and help others
