On my Nuvi 200, after "Where To?", you have to select "Address". My instruction book says: 2.Change the state, country or province if necessary. 3.Touch "Spell City", enter the city/postal code, and touch "Done". Select the city/postal code in the list. (Not all map data provides postal code searching). If you are unsure of the city, touch "Search All". There are further steps, but "Depending on the version of maps loaded on your nuvi, the button names can change and some steps could be ordered differently".
SOURCE: update problem with Garmin Nuvi 255w
I had same problem. I called Garmin customer service who connected me to a computer rep. Garmin hooks with your computer that you have your Garmin plugged into.They can upload the proper software in no time at all.
The rep told me that after I updated my Garmin I might have turned off the unit before it completed updating the new software. You need to wait until the screen with "Where to?" appears.
It works great now. Prepare to wait on hold for a while. I waited just over an hour on Monday, their busiest day.
SOURCE: System Software Missing on Garmin Nuvi 255W
Take a look at this site, http://www.garmin.be/missing.html
Download and unzip the software, plug your garmin in the USB and start
the updater.exe program. It gets you started again. Later on you can
use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
SOURCE: Open the case of a Garmin nuvi 255w
i am wondering why you want to open it.
There are some small parts that will fall out unless you are very careful and even more difficult to put back when you try and close it up
. Other than to change the battery there are no fuses or user repairable parts inside.
SOURCE: System Software missing
go on garmin's website, hook your unit up via usb and install the latest software.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
SOURCE: Garmin Nuvi 255w freezes
mine would constantly cycle in the reboot. I had to clear the stored data by pressng and holding the lower right side of the screen and turning on the gps. once it boots up, it will ask if you want to clear the data memory (will not clear the actual maps). say yes, when it reboots, you will have to redo your personal settings as if it was new out of the box.
