If no drain plug on base of tank you can disconnect fuel line at engine and use an external electric fuel pump connected to fuel line to pump empty
Cars and trucks manufactured since the late 70's have anti-siphoning screens at the bottom of the fill tube to the tank. So, sorry to say, no you can't siphon this new gas. I can truly commiserate with you as it's happened more than once. I've just filled my tank and the vehicle bites the big one. The only way to get to that gas is to drop the tank.
SOURCE: Fuel Gauge Stuck on Full 98 Pontiac Montana
When gauge is pegged at full, usually means a bad ground. Check wires at fuel tank, wiggle around, maybe one came off. The bad news is it is hard to get to without removing the tank. Sometimes you can reach arm in and get to them. Also check body ground at read of van.
SOURCE: Can't fill the gas tank on 98 Toyota Camry
I have a 2000 camry that I just fixed today. there is a vent tube and valve on the carbon canister that is located just behind the gas tank and above the cross member. this vent tube will get plugged up by ( of all things ) spiders, dirt daubers, and I even had a mouse pack the tube with dog food. Just remove the tube and the valve from the canister and clean them out. You will now be able to fill your gas tank again.
SOURCE: Need to siphon gas out of tank. Got a 6 ft. piece
Modern cars can't be SIPHONED anymore!
U go under ur car and drain the FUEL from the tank drain plug!
Taah!
SOURCE: when I try and siphon gas from my 1991 Olds
You can,t there is a ball inside that will let fuel in Its there so if the vehicle rolls over the ball moves beck to stop the fuel spilling out of the tank You would need to disconnect the fuel inlet hose at the tank to siphon fuel from the tank
